SE6a Wiper "Wheel Boxes"
Terry H
Been thanked: 51 times
Re: SE6a Wiper "Wheel Boxes"
Post by Terry H » Sun Apr 17, 2011 6:02 pm
Thanks Bob, lets hope you get a favourable response.
Regards Terry H
1185
DanDrums
Post by DanDrums » Wed Apr 27, 2011 11:44 am
Hi Bob. What's the gen with those ebay wheelboxes? I emailed SVC but they didn't get back to me. I'll ring them but if the ebay ones are alright, let us all know. Mine's just fallen to pieces! :(
Best, Dan
Transit Mk3 in vermillion red G761 MCA 'Gordon'
Scimitar SE6a in faded peppermint green & grey go-faster stripe CCX 36S 'Des'
Gemini Bob
Post by Gemini Bob » Wed Apr 27, 2011 12:04 pm
Hi Dan, it was the bezel and gaskets I emailed about and I have not had a reply.
Bob
HUE 1979 SE6a GTE Auto
If the cap fits wear it.
Scimitars Biggest Fan
DanDrums
Post by DanDrums » Fri Apr 29, 2011 2:09 pm
I've bit the bullet and risked a whole £20 on one off ebay :) The seller says it's 32 teeth and 50mm spindle length. Should do as a replacement for the drivers side. It comes with rubber mounting kit which looks about the right angle. I don't think the chrome ones on offer have the correct chamfer for a GTE so I'm going to re-use the existing rubber ones with an extra soft rubber gasket underneath.
Anyone thinking about doing this job and I know a lot of you are. Access to the driver side wheel box on a 6a is relatively easy, just remove the large diameter plastic air tube going from the 'T' piece to the heater matrix under the steering wheel. There's a cavity you can just about get a small spanner in to to take the back of the box off then the box will just pull off the rack with a few twists and turns (remove the wiper, nut and top rubber first, um, obviously.
The passenger side looks a little trickier. Access is the same, remove the tube and you wan see inside the cavity for the box. There are a lot of wires in the way though and the rack sheath which goes between the two boxes underneath the windscreen will have to be pulled through first. I haven't tried this bit yet but will do if the first wheelbox fits okay and is a genuine replacement.
So for now, fingers x'd I'll keep you updated!
Dan
drcdb15
Has thanked: 32 times
Been thanked: 30 times
Post by drcdb15 » Mon Jun 17, 2019 9:57 pm
Well it's been a while since this thread was current, and it looks as if there was no specific conclusion regarding the wheelbox mounting kits. So I wonder, firstly am I safe in assuming the REAR wiper fitting for Middlebridge will be the same as was used for the SE6A ? And secondly, since it seems every car of the day used this kit, will this kit Lucas P/N 519988 fit the MB rear wiper?
https://www.ebay.co.uk/itm/TRIUMPH-GT6- ... XQJRhRZWJu
Thanks for any guidance.
Chris
Has thanked: 64 times
Been thanked: 196 times
Post by gtcse8 » Thu Jun 20, 2019 8:39 am
Chris I have just changed the rear box on MB41 due to it being seized.
I fitted a NOS Reliant one, just took it out of the box and refitted it so did`nt get part numbers.
But I`m pretty certain the Generic kit will fit the MB
While I had the back end in bits I also had to sort out the hatch lock, the wiper motor, the water jet and pipes, oh and put the petrol cap back on the right way up.
Just got the window seal to do now, one step forward 1 1/2 back.
drcdb15
Post by drcdb15 » Thu Jun 20, 2019 11:51 am
Thanks for that Mark, I'll report back. Sounds like I am doing a lot of the same on MB61 - new rear speakers, drain tubes, hatch seal etc. 8 metres of seal have just arrived from Woolies. 8 metres? All will be revealed in another thread :lol:
Chris
drcdb15
Post by drcdb15 » Wed Jun 26, 2019 12:54 pm
Just to confirm Mark's diagnosis, this kit does fit the MB rear wiper box (so all the SE6> too), but it does NOT fit the front wipers.
Update: Individual rubber washer is called WIPER WHEELBOX SEAL and can be found for 65p here:
http://www.jamespaddock.co.uk/wiper-wheelbox-seal-3
Chris
GarryForder
Has thanked: 24 times
Post by GarryForder » Wed May 20, 2020 5:44 pm
Hi, I'm looking for a couple of wiper wheel box mounting kits for the front wipers on an SE6a. This thread is the closest Ive found, but it clearly states the Triumph - GT6 kit does NOT fit the front wipers.
Any guidance would be greatly appreciated - thanks.
Garry
