Stainless steel door frames
woomera
Post by woomera » Sat Aug 03, 2019 1:06 pm
Hi all,
Can anybody advise if these are still available? I understand the person who originally made the stainless steel frames had stopped and someone else had picked up the baton, but I’ve heard nothing more recently.
My original frames are in a bit of a state now and I am quite urgently looking for replacements (If anyone has good condition original frames they are willing to sell I would be interested in that option also).
Graham
Been thanked: 417 times
Post by peter freeman » Sat Aug 03, 2019 1:53 pm
Not made ta present but there is queue building - club traders probably still have mild steel ones for sale - not cheap but there is no other option just yet.
drcdb15
Has thanked: 32 times
Been thanked: 30 times
Post by drcdb15 » Sun Aug 04, 2019 1:26 pm
Mine also would benefit from replacement, if anyone is building a list of potential buyers...
Chris
Has thanked: 76 times
Post by Will Anderson » Sun Aug 04, 2019 3:49 pm
Having spoken to Mark Wilson about this (with Peter!) at Silverstone the main issues are the machinery to fold the bend at the top of the A post and the fact that almost every set of door frames needs considerable "fettling" to fit.
Mark will correct me if I am wrong but even if he got the machinery to form the bend then he is reluctant to produce them because of the difficulty of fitting these. They are definitely not a case of "Haynes - refitting is the reverse of removal". He had such a hassle with doors on MB42 when trying to fit a good used frame that I think he is blocking anything to do with door frames from his memory!! :)
However, if we all speak nicely to him........... :wink:
Has thanked: 64 times
Been thanked: 196 times
Post by gtcse8 » Sun Aug 04, 2019 4:04 pm
Has anyone rung round and found any NOS ?. :?:
I seem to remember a tale that was circulating that GW had a batch made years ago, but the fit was terrible and not very good. :w
Not had a reply from the Gent whom we think has some jigs/pokery from the original batch produced. :(
I still have One excellent Passenger side to use as a pattern if I can overcome the bending problems on the front edge. :(
Sleepless nights IF I make the investment on these.
The window channels WILL need gluing in, unless I can Hatch a cunning plan to retain them. :wink:
drcdb15
Post by drcdb15 » Sun Aug 04, 2019 5:35 pm
Does it have to be stainless steel? Could an aluminium alloy be used ? These extrusions are produced in huge variety, and presumably forming to the curve of the door would be easier than with steel.
Is Dave Speed there? He did if I understood him correctly some bespoke fitting of the (original) door frame to one door of my car recently. Any views on the feasibility of this, Dave?
From my own (extremely limited) experience of trying to optimise the frame fit, the frame doesn't have any structural function, does it? It just has to stop the glass flapping about and hold it reasonably snugly against the weatherseal.
Chris
Post by gtcse8 » Sun Aug 04, 2019 6:34 pm
Alloy does not like bending, or welding for that matter. :w
I know the MB, or most of them, do not have the embellishers on the top of the bumper mouldings, but these are a pain int arse to keep looking good without being Anodised.
Some years ago I sent a few sets of these "Fancy trims" to a local company for re polishing and anodising, after they said " NO PROBLEM", they stripped back the parts then gave me a bill for £75 and said " NO THANKS" can`t be done.
The door frames are also cosmetic too, and Must follow the curve of the aperture and LOOK right without hitting the top rain gutter( Also anodised Alloy ).
We looked at the cars at Silverstone and most of them had un happy fits and shut lines. :shock:
Has thanked: 31 times
Been thanked: 124 times
Post by Coupe Racing » Sun Aug 04, 2019 7:56 pm
If joining alloy is a problem then why not use a structural adhesive that is cured with heat , as we do at work and the aircraft industry
RonH
Post by RonH » Mon Aug 05, 2019 12:44 pm
What is this interesting product called?
Could possibly be useful for work.
Post by Coupe Racing » Mon Aug 05, 2019 2:05 pm
Sika 497/3 or 489
The aircraft industry uses other types.
All need heat to cure
Post by gtcse8 » Mon Aug 05, 2019 7:30 pm
Bloody good glue if it can bond 0.8 mm to 0.8 mm as good as welding, which is a "Mechanical" joint rather than a "Bonded" joint :?
RonH
Post by RonH » Mon Aug 05, 2019 7:57 pm
Bloody good glue if it can bond 0.08 mm to 0.08 mm as good as welding, which is a "Mechanical" joint rather than a "Bonded" joint :?
0.08mm hmmm 3 thousand of an inch that is thin. So just as thick as cigarette paper?
Has thanked: 100 times
Been thanked: 798 times
Post by philhoward » Mon Aug 05, 2019 8:00 pm
Yep. Some people think the rivets used at the same time are the strength - they’re just used to keep the panels in place whilst the adhesive cures..
Post by gtcse8 » Tue Aug 06, 2019 7:41 am
Decimal point in wrong place :(
Must go to specsavers :lol:
Been thanked: 123 times
Post by ScimmyMike » Tue Aug 06, 2019 11:31 pm
I recall Dave Green fitting new to his GTC, took him a good 8 hours a side, never again he said!
Return to “Middlebridge”
