Ignition cut out
giddo
Ignition cut out
Post by giddo » Tue Jul 16, 2019 10:27 am
I once had a similar fault that was eventually traced to the coil breaking down, mostly when hot. I'm even thinking of moving my Scimitar coil to the side of the engine bay, so here's hoping your new coil zonks it.
Mike Giddens
Servant to Reggie the Reliant
Rev Light
Been thanked: 30 times
Ignition cut out
Post by Rev Light » Wed Jul 17, 2019 5:37 pm
Weeeell,
Coil and new Accuspark unit came today. Ballast type with matching blue coil. However, I cannot start the car now. Red wire connected to 12v from ignition, not via Eureka wire, before anyone asks, i.e. not from the coil.
I was expecting the car to just start. But it did not. Not a peep!
The first suggestion is to rotate the distributer until it fires. However my distributer is fixed in position, as you would expect.
I assume that the small bolt at the base of the distributer needs to be undone? The one that is very difficult, nay almost impossible to get to with a normal socket and extension, behind the timing cover?
Not looking good so far.
Gone from intermittent fault to a complete 'non-starter'
Hey ho.
Dacia is looking promising for France...
SE5a 'Fancier'
Has thanked: 227 times
Been thanked: 52 times
Ignition cut out
Post by willholderogri » Wed Jul 17, 2019 6:01 pm
I had massive problems with the stealth took ages to fire up .normal acuspark was fine though
Ignition cut out
Post by willholderogri » Wed Jul 17, 2019 6:15 pm
1/2 inch socket 3/8 drive long thin extension bar should undo it easy enough
Ignition cut out
Post by willholderogri » Wed Jul 17, 2019 6:16 pm
Make sure you have a spark
Has thanked: 189 times
Been thanked: 1279 times
Ignition cut out
Post by scimjim » Wed Jul 17, 2019 6:36 pm
1/2” socket on 1/4” extension drive is much easier. Was the accusation identical to the one you removed? I think they changed the design after some complaints a while back? Stick a strobe on it to confirm.
Ignition cut out
Post by willholderogri » Wed Jul 17, 2019 6:37 pm
Sorry I meant 1/4 drive
Rev Light
Ignition cut out
Post by Rev Light » Wed Jul 17, 2019 6:41 pm
Yes, it looked different, the back plate was a different shape, so one of the screws went into a different hole. I will see if my brother has a drive that is longer than any I have
SE5a 'Fancier'
Has thanked: 132 times
Been thanked: 875 times
Ignition cut out
Post by philhoward » Wed Jul 17, 2019 7:56 pm
I think it was that unit which required significant adjustment to the timing when fitting - subsequently modified as Jim says..
Ignition cut out
Post by Roger Pennington » Wed Jul 17, 2019 9:43 pm
Wasn't there also a problem where some people found it fouled the vacuum advance, preventing full movement?
I think this lengthy thread in the members' archive may be the one that refers?
Rev Light
Ignition cut out
Post by Rev Light » Sat Jul 20, 2019 1:13 pm
She runs!
Yes the distributer needed rotating 90° to get her to fire. The sensor on the new Acuspark is a similar offset from the one that was removed I set the timing up to 14° btdc. Although that might be a degree or two advanced ? It's a late SE5a, not that it has its original engine. Take her out for a run later and see where we get.
SE5a 'Fancier'
Rev Light
Ignition cut out
Post by Rev Light » Sat Jul 20, 2019 6:50 pm
Well, she ran okay for the 30 or 40 minutes that I was out, if not a little livelier. Not sure there was much wrong with the items I removed, however, as when I was wiring the Accuspark in, I found another dodgy spade connecter from the ignition.
However the exercise has useful, and the car is running. A trip to work and back during the week will give me the confidence to take her to France next weekend.
SE5a 'Fancier'
Ignition cut out
Post by willholderogri » Wed Jul 24, 2019 6:38 am
If you take it to France I have a working stealth you can have as a backup .
