Petrol tank
Jasper53
Petrol tank
Post by Jasper53 » Sun Jun 16, 2019 8:49 am
Hi all, does the petrol tank on SS1 come out through the boot? Put 30 quids in yesterday for the show run and guess what? Been fine till then with quarter tank sat in the garage. Luckily by the time we got there was obviously below the problem as no leak. Car came with a load of spares, guess that’s why there’s a tank in the selection.
Car went great to the show, a lot of people looking and asking what is was. Thanks again to Dave for supplying us with the electrical gizmatroids to get it going.
Cheers, Rob
Has thanked: 131 times
Been thanked: 872 times
Petrol tank
Post by philhoward » Sun Jun 16, 2019 8:53 am
Yes - remove the boot liner and it comes out the boot
Tips for removing the tank - be very careful of the rubber hoses where they attach to the sender (unless it’s a quite late car) and cut, don’t twist (then replace obviously).
Jasper53
Petrol tank
Post by Jasper53 » Sun Jun 16, 2019 9:13 am
Cheers Phil, it’s had some hoses on by the look of it. Don’t like how they are fitted so will probably shorten or replace. Thanks for the info. Rob
Has thanked: 33 times
Been thanked: 51 times
Petrol tank
Post by Alan SS1 » Mon Jun 17, 2019 12:57 pm
what Phil is saying is ' do NOT try and wiggle the hoses off the sender' :-)
I found I could 'just' remove the sender with the hoses STILL attached from the tank, not sure if the tank would be possible to remove out through the boot with the hoses left attached? (and NOT break the sender?)
Jasper53
Petrol tank
Post by Jasper53 » Mon Jun 17, 2019 7:00 pm
The pipes that have obviously been replaced are too long anyway so I’ll cut them off before taking the tank out. When the new one goes in I’ll make the pipes a neater fit by chopping to the right length. As the old saying goes, if it looks right etc.
Been thanked: 164 times
Petrol tank
Post by reliant-reviver » Mon Jun 17, 2019 7:38 pm
Just reading between the lines. Is this the green ti D176 NGN ?
Been thanked: 437 times
Petrol tank
Post by peter freeman » Mon Jun 17, 2019 8:23 pm
Some tanks have the outlet on the bottom which makes getting it out more difficult
Petrol tank
Post by Alan SS1 » Mon Jun 17, 2019 9:34 pm
aye but leave enough length so you can remove a second time :wink:
Jasper53
Petrol tank
Post by Jasper53 » Thu Jun 20, 2019 3:56 pm
‘Tis NGN yes.
Jasper53
Petrol tank
Post by Jasper53 » Thu Jun 20, 2019 3:59 pm
Going to have a go on Saturday. if you see a black smoke cloud billowing over Yorkshire you’ll know I’ve got annoyed and fired it!
Rattling
Been thanked: 21 times
Petrol tank
Post by Rattling » Thu Jun 20, 2019 6:58 pm
Make sure it's the tank before removing as mine leaked from the sender pipes because of them being attached with the wrong clips ! This of course happens when the tank is over the point where the sender is fitted not with a low level just as yours did ,just a thought :D
Colin
1800 Ti
Jasper53
Petrol tank
Post by Jasper53 » Thu Jun 20, 2019 8:54 pm
Was showing half full so worth a look as you say. Cheers :D
Jasper53
Petrol tank
Post by Jasper53 » Sat Jun 22, 2019 10:41 pm
Got the leak sorted. Wasn’t the tank after all that but the filler neck rubber. Seemed to be holding a small amount of petrol after going round a left hander then leaking because it was rotten around the clips. Replaced the fuel pipes anyway as they looked in a similar state. Luckily we had a bit of filler hose left from our Lotus Elan project. Job sorted.
Just a thought, the spare tank we have is not exactly the same as the ti one. What is the purpose of the extra vent pipe on the injection tank? Other than that looks the same. Don’t need the tank anyway, just wondering. :)
Petrol tank
Post by philhoward » Sun Jun 23, 2019 5:17 am
The extra vent pipe is used when they went from a vented to a non-vented filler cap.
Rattling
Petrol tank
Post by Rattling » Sun Jun 23, 2019 6:22 am
Do you know what year model that was Phil ?
Colin
1800 Ti
