GTC Steering Lock
giddo
GTC Steering Lock
Post by giddo » Sun Apr 14, 2019 6:59 pm
Today the ignition key broke leaving half in the lock. So far I've removed the wheel, multi-switch and instrument panel, I've unplugged all the cable bunches and undone the top clamp holding the column to the cross-tube so its dropped down a bit.
Can anyone advise on how to remove the lock / switch assembly from the column or undo the shear bolts ?
I presume there is no trick way of getting the broken bit of key out. (I do have a spare, usable key )
Help please
Mike Giddens
Servant to Reggie the Reliant
Terry H
Been thanked: 53 times
GTC Steering Lock
Post by Terry H » Sun Apr 14, 2019 7:15 pm
Last time I did one like this I used my stud extractors. As these on Ebay. https://www.ebay.co.uk/itm/Damaged-Bolt ... ctupt=true Hope this helps.
Regards Terry H
rebel alliance
Been thanked: 104 times
GTC Steering Lock
Post by rebel alliance » Sun Apr 14, 2019 7:16 pm
I think you may be able to remove the part with the key in by removing a small cross head screw..if so take it to a locksmith....i usually hacksaw a slot in the shear bolts and undo with a screwdriver
giddo
GTC Steering Lock
Post by giddo » Fri Apr 19, 2019 11:55 pm
Thanks to Terry H and rebel alliance, In the end I found a local locksmith who specialises in autromotive stuff and he got the broken bit out and made new ignition keys to suit I will post the full story in a day or two............
Mike Giddens
