Stuck distributor
chips01
Has thanked: 83 times
Stuck distributor
Post by chips01 » Sat Apr 13, 2019 8:29 pm
Well, this car never stops amazing me and how much of a fight she can put up to stop me renovating her. I was going to run a strobe light to check the ignition timing. Set strobe up and slackened distributor hold down clamp. Check to make sure it could be rotated. NO the bloody thing is seized solid and will not move. Is there anyone on here who has had the unfortunate stuck distributor situation?
rebel alliance
Been thanked: 97 times
Stuck distributor
Post by rebel alliance » Sat Apr 13, 2019 9:06 pm
Common problem from what i'v read..pour a bit of diesel around the base and leave for a day of two
scimitargtc
Been thanked: 22 times
Stuck distributor
Post by scimitargtc » Sat Apr 13, 2019 9:08 pm
Yup, it is a struggle but it will come out,, does the dizzie shaft stay put when you twist the body (wither cap off) last resort I can think of is to drain the oil remove the sump take off the oil pump and pencil drive and gently tap it out from underneath,,,if you then need a replacement dizzie I believe I have a couple lying around inc a brand new AccuSpark one
chips01
Stuck distributor
Post by chips01 » Sat Apr 13, 2019 9:20 pm
Well what can I say. Many thanks for your comments. Never ceases to amaze me the number of quirky problems that keep getting thrown up. I am still here and will not be beaten.
scimitargtc
Stuck distributor
Post by scimitargtc » Sat Apr 13, 2019 9:23 pm
Rereading your problem it seems 5he dizzie won’t rotate, then that being the case suggest the clamp bolt (3mm) is not slackened sufficiently
chips01
Stuck distributor
Post by chips01 » Mon Apr 15, 2019 9:45 pm
No the clamp bolt is loose and the clamp plate is free and moving easily.
scimitargtc
Stuck distributor
Post by scimitargtc » Mon Apr 15, 2019 9:54 pm
But the dizzie won’t rotate? But the car runs.... others will have more wisdom but it has to be catching on something
Has thanked: 178 times
Been thanked: 1228 times
Stuck distributor
Post by scimjim » Mon Apr 15, 2019 10:04 pm
Alloy dizzy in a steel block - if it’s not lubricated and occasionally moved, it’ll sieze. Persistence, patience and penetrating fluid to start with - heat and aggression if that doesn’t work :D
scimitargtc
Stuck distributor
Post by scimitargtc » Mon Apr 15, 2019 10:10 pm
Perseverance then,, and last 2 options being drop the oil/sump oil pump pencil drive and whack it out from underneath or final last gasp effort wreck it all from above with an electric drill around the ally dizzie and fish the bits out... yo can see Y wife and kids nickname me bodgit and scarper... as long as it passes the “am prepared to let my wife go out in the car” safety check I’m happy
rebel alliance
Stuck distributor
Post by rebel alliance » Tue Apr 16, 2019 6:04 am
So is the timing actually out ?
chips01
Stuck distributor
Post by chips01 » Tue Apr 16, 2019 7:04 am
My own stupid fault really. Car runs fine but I wanted to check that the timing was correct so highlighted timing mark and was going to check static timing first when I found the problem. BUT I could have left it and carried on but NO because it is wrong I have to fix it. Been soaking with wd40 and have access to the block rh side of dizzie so will bang heat on it. Have a feeling there is a new dizzie on the horizon.
chips01
Stuck distributor
Post by chips01 » Tue Apr 16, 2019 7:06 am
Only the dizzie body that is seized. Rest appears to be fine though may not be after I have loosened it.
Has thanked: 32 times
Been thanked: 132 times
Stuck distributor
Post by Coupe Racing » Tue Apr 16, 2019 7:19 am
If you drill it just consider where the swarf will go
ard126k
Been thanked: 42 times
Stuck distributor
Post by ard126k » Tue Apr 16, 2019 2:27 pm
When I had this problem I got a crowbar under the wide part of the dist. body, resting on a nearby head bolt. Applied upward leverage and at the same time tapped gently on the other side of the dist.
Alex.
1971 SE5 1977 SE6 1982 GTC
rebel alliance
Stuck distributor
Post by rebel alliance » Tue Apr 16, 2019 2:35 pm
Hrmmm its your car but if the timing is ok why go medieval on the poor dizzy.....never had one stick but i would forget wd40 try plus gas or diesel for a week or two then remove the vacuum unit and use a strap wrench to twist it back and forth once the engines nice and hot might help 😊
