Power steering pump bolts
scimitargtc
Post by scimitargtc » Wed Apr 10, 2019 9:38 pm
Ok to get my 6a restarted replaced ignition system no start found dry carb bowl so off with the carb then off with the fuel pump and to get that off the power steering pump comes off and to get it back on the mounting bracket to front engine cover comes off to aid alignment then lose 1 of the pump to front mounting bracket bolts and also note the rear pump bracket is not bolted to the engine.. so does anyone know the bolt size I need for the front bracket to pump or better still has 1 they can sell me....
1979 se6a auto pas 3.0v6 (unnamed)
Nigel Clark
Been thanked: 46 times
Post by Nigel Clark » Wed Apr 10, 2019 10:03 pm
There are two different sizes of bolt used on the power steering pump mounting. Some are 5/16" unf and the others are 3/8" unf.
Hope this helps,
Nigel
scimitargtc
Post by scimitargtc » Wed Apr 10, 2019 10:30 pm
Thank you Nigel
Has thanked: 147 times
Been thanked: 527 times
Post by Roger Pennington » Thu Apr 11, 2019 12:02 pm
Also at least one of the bolts has a spacer, which is easily lost on removal, and difficult to replace.
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Thu Apr 11, 2019 12:36 pm
which pump do you have? and also is the rear bracket a piece of angle bolted to the head, I may have them
Geraint
Sabre ti, se5, GTC, 6b.......
scimitargtc
Post by scimitargtc » Thu Apr 11, 2019 12:36 pm
Thanks Roger have the spacer thought it was something id out in!
scimitargtc
Post by scimitargtc » Thu Apr 11, 2019 12:40 pm
My pump is the style on the left side of your photo
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Thu Apr 11, 2019 1:01 pm
one on the left into the cylinder head (may/will need cutting down to suit your bracket) one on right from pump, if these are what you need send me your address by PM and I will post them to you Monday....
Geraint
scimitargtc
Post by scimitargtc » Thu Apr 11, 2019 2:10 pm
Yes please. Pm sent
