SS1 heater and/ or fan upgrade
Jhdelta
Post by Jhdelta » Mon Apr 08, 2019 9:24 pm
I heard somewhere an astra fan fits and makes a big improvement but the one I got from a MK3 astra (i think) is a larger diameter and longer so will take a lot of messing on to fit.
Are there other alternatves people have found?
thanks
Has thanked: 82 times
Been thanked: 128 times
Post by reliant-reviver » Mon Apr 08, 2019 9:28 pm
MK2 Astra provides you with the same motor and a bit double the width (adjust accordingly, Reliant kindly cut it in half!)
Tony Idle used a Mondeo one I believe and I know I have seen others, usually put in through the external side of the casing.
Has thanked: 135 times
Been thanked: 498 times
Post by Roger Pennington » Thu Apr 11, 2019 2:30 pm
The later Reliant ones (where the fan motor is on the correct (engine) side of the unit, are very much better IMHO but as there probably aren't many of those about, you may be better looking for an alternative.
Post by reliant-reviver » Thu Apr 11, 2019 5:44 pm
I believe GW have the 3rd variant of SS1 (sabre) blower available at a price (a 3 figure one iirc)
Has thanked: 122 times
Been thanked: 911 times
Post by scimjim » Thu Apr 11, 2019 6:00 pm
I’ve just fitted a Nissan Micha K11 motor to G97 so that I could notch the housing for clearance. Seems to work well.
Jhdelta
Post by Jhdelta » Thu Apr 11, 2019 8:30 pm
any pics of your micra version?
Post by scimjim » Thu Apr 11, 2019 8:52 pm
Google pic
