V6 essex timing gear
Sarecen
Post by Sarecen » Mon Apr 08, 2019 8:22 am
Hi all
As my essex is out of the car for a number of issues, I checked the timing gear which is the old nylon type.
Question is should I replace it with steel or alloy?
Do I need to replace both gears? (even though the crank gear looks flawless)
Thanks in advance
Sarecen
Been thanked: 351 times
Post by peter freeman » Mon Apr 08, 2019 8:27 am
2 Gears. Steel you don't alloy you do - Alloy is quieter with steel you could be lucky ( like me ) and also have no noise.
Been thanked: 58 times
Post by Nick » Mon Apr 08, 2019 8:28 am
Yes, the larger fibre gear only needs to be replaced. Steel and alloy are available. I think the club may do a group buy. I had steel which can “sing” a bit when new. Major suppliers like burtons sell them. The fibre gear may fail drastically :oops:
scimitargtc
Post by scimitargtc » Mon Apr 08, 2019 9:15 am
Had a fibre break for on me, just as I as starting the car. Replaced with steel no issues no noise but do the change,
1979 se6a auto pas 3.0v6 (unnamed)
Sarecen
Post by Sarecen » Mon Apr 08, 2019 8:35 pm
thanks for your feed back, I'll source a steel one
D
roymck
Has thanked: 15 times
Been thanked: 24 times
Post by roymck » Tue Apr 09, 2019 3:18 pm
Ric Wood does not sell or recommend Steel timing gears , he,s the V6 Guru
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Tue Apr 09, 2019 4:06 pm
John Wade might disagree although he did sell various “grades” depending on measurements off your actual engine, I believe. That does suggest his gears were made to much better tolerances than Ford made the actual engines..
Has thanked: 151 times
Been thanked: 27 times
Post by willholderogri » Tue Apr 09, 2019 4:29 pm
I use steel in mine I would never go back to nylon
turboscim
Post by turboscim » Tue Apr 09, 2019 6:36 pm
I have had a John Wade steel gear for over 10 years and have used 6500 rpm with no problems and no undue noise
scimitargtc
Post by scimitargtc » Tue Apr 09, 2019 7:42 pm
JW supplied mine and no no no problems
RodH
Post by RodH » Tue Apr 09, 2019 8:45 pm
On car SOS.(Ford Capri Mk.1. S6 E10. 22 min in)
John Wade said in person "Steel timing gears can cause camshaft fracturing at rpm over 6000"
82 GTC, 84 SE6b, 77 SE6a,
Saab C900 T16S Vert, 9000 2.3FPT lpg, C900i Vert.
Post by peter freeman » Tue Apr 09, 2019 8:59 pm
I have never had my engine over 4,000 rpm let alone 6000 - probably why it has done 300,000 miles
turboscim
Post by turboscim » Wed Apr 10, 2019 7:56 am
Car s o s was Ric Wood not J. W.
Sarecen
Post by Sarecen » Wed Apr 10, 2019 12:17 pm
New gear kit sourced and on its way
Thanks for the replies
Dave g
Jimscim
Post by Jimscim » Wed Apr 10, 2019 3:22 pm
I changed my Fibre gear for a Burton Steel one . The noise on start up was awful. It whined like a turbo . I found the noise to be unacceptable and changed back to the Fibre gear. , yes a decision I may come to regret 🙏.
RSSOC 3408 1979/80 Scimitar 6a . Mulberry with white stripe .
