SS1 diff mount help
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 5:00 pm
Hi everyone!
Just started work on our SS1. Been parked up in the rain for 3 years and never been on the road in our ownership. I'm taking it on a 1000 mile round trip in 7 weeks. I might be mad!
Bit of advice needed.
What is the steering column originally from? I need to purchase a replacement top bush.
What are the diff mounts from?
Currently the diff is held in place with a block of wood after the chassis mount has broken! Looks like it's been that way for many years! Going to need a new mount to bolt in once I've welded up the chassis.
I also have quite a lot of rot to fix! Hopefully body off tomorrow.
Been thanked: 50 times
SS1 diff mount help
Post by Old and Slow » Fri Apr 05, 2019 5:03 pm
Please take pictures showing progress; always appreciated.
And good luck!!!
Been thanked: 116 times
SS1 diff mount help
Post by Oaksey » Fri Apr 05, 2019 5:45 pm
Column top bushes are available from the suppliers.
If you mean the diff cradle, then that's bespoke. If you mean the rubber mounts, IIRC they're also bespoke and not available - they've been on the remanufacture request list for a while
2005 Honda S2000
Has thanked: 130 times
Been thanked: 951 times
SS1 diff mount help
Post by scimjim » Fri Apr 05, 2019 5:45 pm
Welcome to the forum :D
Early chassis diff mount cracking was known about and Reliant issued a repair instruction (basically a plate welded over it). I have s/h mounts if you need.
The steering column is off an SS1 :D I think I have one spare - which bit is actually worn?
SS1 diff mount help
Post by scimjim » Fri Apr 05, 2019 5:50 pm
I thought they were Ford? Can’t see them in the remanufacture thread?
SS1 diff mount help
Post by Oaksey » Fri Apr 05, 2019 5:52 pm
Neither could I when I just looked tbf. I thought I could remember Phil A saying a while ago that he hadn't found any the same and it was maybe worth having them made? Having said that, I can't remember what I did yesterday so I could easily be wrong.
2005 Honda S2000
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 6:16 pm
Thanks for the replies!
It was the rubber diff mounts I was referring to, turns out I do have it, but it's underneath...... Will add photo to show.
Column bush is the on between inner and outer at the top. I have machined up an aluminium one, but it will be a bit rattly compared to the original plastic, so a proper replacement would be better if available.
Thought I had added pictures, will try again!
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 6:17 pm
Diff mounting area.
Has thanked: 87 times
Been thanked: 134 times
SS1 diff mount help
Post by reliant-reviver » Fri Apr 05, 2019 6:22 pm
Did I say that?
QRG has had them on the stall at Curborough past coupe years. Nos mounts front and rear iirc About 20 quid each.
Column top hat bushes readily available. Shared with other vehicles.
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 6:29 pm
Ooh, that's good news. Do you know what other vehicles they are shared with? My googling session did not bear any fruit!
Has thanked: 33 times
Been thanked: 92 times
SS1 diff mount help
Post by swoakes » Fri Apr 05, 2019 6:57 pm
That's my old car :D
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 6:59 pm
Wow! It used to look great! When was that?
SS1 diff mount help
Post by swoakes » Fri Apr 05, 2019 7:03 pm
2007 :shock:
I have more photos if you want them :wink:
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 7:05 pm
That would be great, thanks! Looking very sorry for its self now. Previous owner left it under a cover that ruined the paint. I also only have the hard top. Any history you have on it, I'd be interested to know.
SS1 diff mount help
Post by gtcse8 » Fri Apr 05, 2019 7:07 pm
Where are you Martin?
I think the GTE steering bushes will fit and I have a few spares.
bush internal.jpg (96.13 KiB) Viewed 1251 times
bush external.jpg (89.85 KiB) Viewed 1251 times
They are flared internally and externally to get a better fit with no slop.
