SE6b Steering coupling question
metalmoth
Post by metalmoth » Mon Apr 01, 2019 9:45 pm
I’ve just taken the lower steering UJ off my 6b to replace it and I noticed that where there is normally a flexible rubber disc on the column there is a metal one that is like a huge washer in its place. Is this right on a 6b? The manual says the later PAS cars are different to early ones. Has anybody come across this ?
1982 SE6b factory black aka The Beast
What could possibly go wrong?
Been thanked: 241 times
Post by AJL Electronics » Mon Apr 01, 2019 9:55 pm
That is the correct part.
metalmoth
Post by metalmoth » Mon Apr 01, 2019 10:34 pm
Thanks for the reply. I just wanted to make sure before it went back together
metalmoth
Post by metalmoth » Thu Apr 04, 2019 5:43 pm
It’s al back together but I don’t understand why they use a metal disc instead of a flexible one.it doesn’t make sense
Post by AJL Electronics » Thu Apr 04, 2019 5:53 pm
A rubber disc would cause vague steering, you don't want any flex there. It is more of a shock absorber in the event of an accident, rather than a flexible coupling.
mod edit
guybetts
Has thanked: 31 times
Been thanked: 8 times
Post by guybetts » Thu Apr 04, 2019 7:06 pm
It's a big rubber donut coupling on some Coupe's, as used on Triumph 2000's
GTC Registrar
metalmoth
Post by metalmoth » Thu Apr 04, 2019 9:07 pm
I only raised the question as everyone else seems to use a flexible one that’s all.
mod edit
metalmoth
Post by metalmoth » Thu Apr 04, 2019 9:43 pm
Nobody likes a smart arse
metalmoth
Post by metalmoth » Thu Apr 04, 2019 9:45 pm
People post on here in good faith.
