Trunnions SE5A
CarlosVanDango
Trunnions SE5A
Post by CarlosVanDango » Sun Mar 31, 2019 9:28 pm
quick question guys
how is the lower trunnion held onto the front hub?
the brass part - has is got bushes in it or not?
there is play in mine thats all, i'm looking at replacing the brass part, is that what i need to do or will there be some other thing thats worn?
cheers :D
Has thanked: 140 times
Been thanked: 995 times
Trunnions SE5A
Post by scimjim » Sun Mar 31, 2019 10:10 pm
It’s screwed onto the bottom of the upright. Is the play in the upright/trunnion threads or the lower wishbone bolt (the long one that passes through the trunnion)? If it’s the former, it could separate, putting your wheel into the wing.
CarlosVanDango
Trunnions SE5A
Post by CarlosVanDango » Sun Mar 31, 2019 10:39 pm
i think the play is in the upright - i'll have a closer look i was replacing the top ball joint as that is tight causing the steering to be heavy i only noticed the play after, the bottom is really free to turn
so its the brass part i need to replace?
seems a bit of a crap design :? whats the advantage of having it threaded?
Trunnions SE5A
Post by scimjim » Sun Mar 31, 2019 10:59 pm
They get a hard rep when they need greasing regularly and are relatively expensive to replace (particularly the bespoke PAS trunnions) - but actually It might have been replaced once or twice in the cars life, making it maybe 10-25 years old - how long do balljoints last? Trunnions were only replaced by balljoints due to production costs,
It sounds like the brass trunnion needs replacing, it’s deliberately softer than the upright, so as soon as you find any slack you replace it before the upright gets damaged.
CarlosVanDango
Trunnions SE5A
Post by CarlosVanDango » Sun Apr 07, 2019 11:08 am
well i got the new trunnion and fitted it on but there is still a bit of play :(
i can't help but think this would be much better converted to a bottom ball joints, i've read loz's thread on here where he has converted an SE6, thinking of a similar idea for this :idea:
anyone else converted to ball joints?
derekoss
Trunnions SE5A
Post by derekoss » Sun Apr 07, 2019 12:58 pm
I looked at going for ball joints but in the end renewed everything as standard. Then I added an automatic lubrication system.
Tapped the grease hole in the upright and fiitted 4mm nylon tube to an industrial lubricator. Every time the ignition is switched on around 2cc of my favoured (not getting in that!) lubricant gets pumped in. Important to seal the bottom of the trunnion with solder.
The tube could be terminated with a grease nipple for manual pumping.
Saves me crawling around !
Derek
Trunnions SE5A
Post by scimjim » Sun Apr 07, 2019 1:07 pm
Define “much better” :D
Has thanked: 162 times
Been thanked: 29 times
Trunnions SE5A
Post by willholderogri » Sun Apr 07, 2019 3:34 pm
I looked at going for ball joints but in the end renewed everything as standard. Then I added an automatic lubrication system.can I have tech details please
Derek
any chance I could have some photos and tech details please
CarlosVanDango
Trunnions SE5A
Post by CarlosVanDango » Sun Apr 07, 2019 4:31 pm
cheaper for one :lol:
do any cars still have trunnions?
if you fit a common bolt on bottom ball joint you can replace it with an off the shelf new of for under £20 and a lot easier than messing with the trunnions
CarlosVanDango
Trunnions SE5A
Post by CarlosVanDango » Sun Apr 07, 2019 4:33 pm
Derek
this though crossed my mind, well not the automatic lube system but piping all the grease nipples to an easily accessible manifold
Trunnions SE5A
Post by scimjim » Sun Apr 07, 2019 6:57 pm
Cheaper rarely means better. The only real advantage is ease of replacement.
Balljoints May be cheaper in the short term (even including modification costs) - but certainly not long term. Balljoints (and their boots) just don’t last long compared to trunnions.
CarlosVanDango
Trunnions SE5A
Post by CarlosVanDango » Sun Apr 07, 2019 7:27 pm
not so sure about that my scimitar's on 100k and the trunnions have worn out i did similar on a mk5 transit flareside and that was still on the original ball joints - just looked on ebay and they are £10
also the force on a transit one will be double that of a scimitar
cheaper is often just a case of mass production - something your never going to get with scimitar spares
