Warning light terminals
mada85
Post by mada85 » Thu Mar 28, 2019 7:29 am
Hello, I am close to finishing rewiring my se6, I am just wiring up the dash area now. I am after the terminals for the warning lights i.e indicator tell tale etc. I think I have found the terminals but it comes with the socket/connector and is more expensive than I ideally want to pay :
https://www.ebay.co.uk/itm/LUCAS-88SA-l ... ctupt=true
I am aware I could just solder the old plug and wires in or fit an inline plug but Ideally I would just like new pins.
Here are a couple of close up pictures of the terminals, does anyone know the name of them or where I could get some? I think they are Lucas terminals.
Thank you
Been thanked: 237 times
Post by AJL Electronics » Thu Mar 28, 2019 8:20 am
Bog standard uninsulated Lucar connectors. Ideally need the proper crimp tool to fit, but can be done carefully with pliers.
mada85
Post by mada85 » Thu Mar 28, 2019 8:59 am
My understanding of a Lucar is just a female spade terminal like this
These terminals seem very different to that, am I missing something? These terminals are to take a round pin.
Thank you for your help AJL
Terry H
Been thanked: 49 times
Post by Terry H » Thu Mar 28, 2019 9:14 am
you can probably get away with using something like these, they probably come in different sizes. https://uk.rs-online.com/web/p/products ... lsrc=aw.ds
Regards Terry H
Been thanked: 354 times
Post by peter freeman » Thu Mar 28, 2019 9:44 am
You said it yourself that is a SPADE terminal - that's not what you photographed.
mada85
Post by mada85 » Thu Mar 28, 2019 10:10 am
Yes I agree, I was trying to give an example of my understanding
Post by AJL Electronics » Thu Mar 28, 2019 11:00 am
Apologies! It looked like a Lucar to my metal infused eyeball! What you need then (I think) is a different type of terminal known as Lucas RISTs. Your terminal looks like a crushed circular terminal, otherwise I haven't come across one before.
Last edited by AJL Electronics on Thu Mar 28, 2019 11:03 am, edited 1 time in total.
Post by AJL Electronics » Thu Mar 28, 2019 11:01 am
mada85
Post by mada85 » Thu Mar 28, 2019 11:41 am
Thank you I shall look into this. I had a thorough search last night online and struggled to find them
mada85
Post by mada85 » Sat Mar 30, 2019 6:31 pm
Just in case anyone else is after these in the future I tried many different round terminals including Rists and had no luck of getting anything to fit and lock. I spoke to a few people selling the terminal & connector kits and none said they would sell the terminals separately. I bit the bullet and bought the Connector and terminals and they are correct and identical to the originals. I'm still none the wiser to the correct terminal name though
