Headlight Motor Relay
1800oldb
Post by 1800oldb » Wed Mar 27, 2019 8:31 am
Greetings,
searched the forum but can't find the answer to my question.
What is the P/No of the headlight motor relay?
This is the bottom relay of the three in the column nearest the rear wall of the engine compartment.
In the handbook it is labelled 'Headlamp Motor Switching'.
If the relay is obsolete and unobtainable, is there an alternative?
I've tried a relay of similar configuration but it didn't work. However, I don't know if that one was serviceable in the first place.
Any information or advice gratefully received.
Mike
Has thanked: 140 times
Been thanked: 998 times
Post by scimjim » Wed Mar 27, 2019 8:37 am
All of the relays in the block are 5 pin as opposed to the more "normal" 4 pin - there are two types though - A&B
not specific to the car and all readily available.
Diagnose by swapping with one of the others?
I have a tin full of them if you need an original.
Has thanked: 155 times
Been thanked: 534 times
Post by Roger Pennington » Wed Mar 27, 2019 11:26 am
Not quite clear from your note, Jim, are type A & B interchangeable, or do you need to change like for like?
Post by scimjim » Wed Mar 27, 2019 3:31 pm
no, they're not interchangeable - IIRC there is a legend on the actual relay that will identify type.
Post by Roger Pennington » Wed Mar 27, 2019 3:33 pm
That's interesting, thanks. :)
1800oldb
Post by 1800oldb » Wed Mar 27, 2019 5:57 pm
Thanks Jim.
It's a Type B. There's no legend on my relay, just some numbers.
I'll try Halfords tomorrow - it ought to be quicker than posting from Gloucester.
Mike
1800oldb
Post by 1800oldb » Thu Mar 28, 2019 4:29 pm
Greetings, one and all.
Quote "it ought to be quicker than posting from Gloucester"
It would be, if I could obtain a relay at my local Halfords but they don't appear to sell relays anymore!
My local car specialist provided a relay. He checked the numbers and lay-out and pronounced it was the "right one".
Installed relay in car and zilch. Lights never even 'popped up'.
Re-installed the old relay and everything worked as it should. Probably the WD40 squirted onto the innards of the relay.
Not leaving things to chance, though.
Jim, a pm is going to be winging your way within the next couple of minutes.
Thanks to all.
Mike
Post by scimjim » Thu Mar 28, 2019 7:08 pm
PM received - I’ll post one tomorrow Mike.
Just for reference, I photographed the top of a standard relay
