New door locks
Has thanked: 144 times
Been thanked: 1013 times
New door locks
Post by scimjim » Wed Apr 10, 2019 11:46 am
Apart from SE6, it's also Triumph isn't it?
roymck
Has thanked: 15 times
Been thanked: 24 times
New door locks
Post by roymck » Wed Apr 10, 2019 11:48 am
Triumph 2000 Mk1 and Mk2 bootlock
Eric2205
New door locks
Post by Eric2205 » Wed Apr 10, 2019 1:29 pm
Hi, thanck you for the answer
Penfold13
New door locks
Post by Penfold13 » Wed Apr 10, 2019 9:29 pm
Joe. wrote:
Tue Apr 09, 2019 1:43 pm
Ignition lock is shared in common with an MG Midget.
I just took a look at Midget ignition locks and they do look the same, but there’s a lot of different model numbers knocking around. Are they all the same? Is it the whole mechanism, i.e. the steering lock as well, or just the ignition lock?
Thanks,
Chris
‘72 SE5A
Joe.
New door locks
Post by Joe. » Thu Apr 11, 2019 12:44 am
I fitted a second hand one off an MG midget 1500 during my rebuild in 2011, (my car is also a 1972 5a.) I Bought the switch via ebay. I used the whole unit, Steering Lock, Barrel and key. The Lucas ignition switch fits into the back and is retained by a small screw.
On very late 5a's (1975) the the steering lock it may be slightly different, as there were a few cars at the end of the production run where the ignition key was in a slightly different position. Enough to mean Reliant altered the dashboard to suit it.
Penfold13
New door locks
Post by Penfold13 » Thu Apr 11, 2019 4:32 pm
Thanks Joe, that’s on my ever growing list of things to buy now!
Another tangent from me, is there a list which shows which bits are compatible with bits from other cars to save me asking you all lots of questions?
Thanks again,
Chris
‘72 SE5A
Has thanked: 65 times
Been thanked: 647 times
New door locks
Post by philhoward » Thu Apr 11, 2019 5:54 pm
Eric2205
New door locks
Post by Eric2205 » Fri Apr 12, 2019 3:56 pm
Thank you for the link : I did the order
Penfold13
New door locks
Post by Penfold13 » Sun Apr 14, 2019 9:14 pm
Thank you, order placed too!
‘72 SE5A
