3rd gear position back of rod catching side of underbody
Kevin
Post by Kevin » Sat Mar 23, 2019 5:53 pm
I have just replaced the gearbox selector arm bushes & replaced the gear lever bushes also.(GTC)
After reconnecting the selector rods, when putting the gear lever in to 3rd gear position, the back of the 3,4th gear selector rod catches on the side of the underneath tunnel body work, jamming the system.
I can not move the gear change mechanism over any more to make more clearance.I have not made any changes to the rods, installing them exactly as they came out.
Before starting any work on this, the 3/4th gear rod was already very close to the body work.
Does anyone have any idea where I have gone wrong with this?
Thank you for your help.
Kevin.
Has thanked: 74 times
Been thanked: 103 times
Post by Oldconn » Sun Mar 24, 2019 7:41 am
Connect the rod on the inside of the lever, not on the outside?? :)
Post by Roger Pennington » Tue Mar 26, 2019 1:26 am
I'm not an expert on this, but when you reassembled the linkage, did you use the alignment rod method to set the position of the levers with respect to the neutral position, as detailed in the manual, before connecting everything up?
Kevin
Post by Kevin » Tue Mar 26, 2019 11:42 pm
I went back & used the alignment method with the gear lever arms pinned in the neutral position. I had to put a bend in the 3rd & 4th gear rod & adjust the length to provided enough clearance from the bodywork. I am not sure why I had to do this but it is now working ok.
Thank you all for your help.
Kevin.
Post by Roger Pennington » Wed Mar 27, 2019 11:45 am
Maybe somebody had adjusted the rods in the past, in an attempt to compensate for the worn linkage bushes, so they were now out of position when reassembled with new bushes?
giddo
Post by giddo » Fri Mar 29, 2019 2:43 pm
Apologies if I'm too far off topic here but can someone tell me where the overdrive inhibit switch ( sensing 3rd/4th) is on an 84 GTC ?
Mike Giddens
Servant to Reggie the Reliant
Been thanked: 840 times
Post by philhoward » Fri Mar 29, 2019 3:16 pm
Bolted to the underside of the gearlever housing.
Post by philhoward » Fri Mar 29, 2019 3:17 pm
giddo
Post by giddo » Sat Mar 30, 2019 11:16 am
Thanks a lot Phil, My electronic copy of the 6a manual does not include that drawing and searching on this forum did not turn up any helpful info.
Am I right in thinking there is not a Manual for 6b / se8 ?
Mike Giddens
Has thanked: 176 times
Been thanked: 1222 times
Post by scimjim » Sat Mar 30, 2019 1:33 pm
That picture should be in the manual. There’s a parts manual for the 6b/GTC but no workshop manual - just a service bulletin/ supplement for the 2.8.
giddo
Post by giddo » Sat Mar 30, 2019 10:42 pm
Sorry chaps, my mistake.
Exploded diagram of gear-change found in section G transmission - why did I not look that far down :oops:
I was out in the car this evening, about 30% of the time O/D fails to engage, hitting the gear-lever towards my left knee usually brings it IN.
Otherwise change to neutral and back quick, fixes it. I'm expecting to find dirty contacts or a loose securing bolt
Mike Giddens
giddo
Post by giddo » Tue May 07, 2019 8:21 pm
Outcome
Car now all back together again and O/D now perfect. The rearmost of the three bolts holding the gearchange assembly to the tunnel was loose. I'm certain over time the rod for left / right movement of the gearlever was progressively pushing the switch away leaving it de-activated. My thanks to all respondees above.
Mike Giddens
