Noise after changing timing wheel
roymck
Has thanked: 15 times
Been thanked: 24 times
Post by roymck » Fri Mar 22, 2019 2:43 pm
Sorry lads , so many questions . Changed the timing wheel for a QRG alloy version . Started car today for 1st time and there seems to be a rhythmic knocking from timing cover . Thought it might be the fuel pump catching so pulled it off and run engine again but its still there.
It want there before , so any thoughts before I pull it all off again . Bolt rubbing on timing wheel?
One day all these questions will stop , I promise !
Has thanked: 58 times
Been thanked: 624 times
Post by philhoward » Fri Mar 22, 2019 2:46 pm
Roll pin that holds the eccentric cam for the fuel pump catching a rib?
roymck
Post by roymck » Fri Mar 22, 2019 3:51 pm
Hi Phil , can’t see how it could be roll pin as timing wheel hole is blind and pump ecentric is in place and fully tightened .
If I turn engine over by hand can’t feel anything touching . Very odd!
My wheel don’t whine it just knocks , when its running you can feel it quite strongly if you put your hands on timing cover .
Been thanked: 94 times
Post by Coupe Racing » Fri Mar 22, 2019 5:02 pm
Not being funny but is the bolt holding the cam wheel on tight ?
Is the woodruff key in place ?
Does the knock increase with revs
May be back lash is too big
Has thanked: 147 times
Been thanked: 527 times
Post by Roger Pennington » Fri Mar 22, 2019 5:09 pm
Did you change the front crank oil seal, and did you centre the timing cover on the crank pulley before tightening the bolts on replacement?
roymck
Post by roymck » Fri Mar 22, 2019 6:10 pm
Torqued cam wheel bolt to correct setting, woodruff key in place checked that 1st time . Yes noise increases with revs .
Backlash seemed pretty good when I bolted it all up .
Yes changed the crank oil seal and centred is up best I could , then torqued up crank pulley . Run it without fan belt just in case it was water pump .
Just hope if I strip it down there is witness marks , hate to strip it down and find nothing .
nickm
Post by nickm » Fri Mar 22, 2019 6:17 pm
Which type of front cover do you have?
I have heard the early type can foul the later type wheel.
Although I didn't have that problem myself.
David Tew
Post by David Tew » Fri Mar 22, 2019 6:19 pm
Strange one there Roy. All good suggestions above.
A couple of other thoughts. If you can actually feel the vibration through the cover I would suspect it's the wheel catching somewhere ... perhaps on one of the bolts holding the cover plate to the engine?
A really unlikely one (but everything is worth considering), is the new wheel exactly the same width as the original? If it's even slightly thicker it could well cause interference issues.
I think the best option is to remove the new gear and inspect it. A hassle I know but you'll soon see if it's catching anywhere. If it's clean then it must be a fitting issue.
Don't give up. As Churchill said, “Never give up on something that you can’t go a day without thinking about”. :wink:
roymck
Post by roymck » Fri Mar 22, 2019 6:36 pm
Early type !
rebel alliance
Been thanked: 54 times
Post by rebel alliance » Fri Mar 22, 2019 7:46 pm
Fuel pump fixing stud ?
roymck
Post by roymck » Fri Mar 22, 2019 8:33 pm
Possibility but would think that’s more consistent noise . Looking more likely it’s all got to come apart again .
rebel alliance
Post by rebel alliance » Fri Mar 22, 2019 8:41 pm
If the wheels got a slight wobble it may be hitting one of those studs...take the pump off and look for marks 😊
Post by Coupe Racing » Fri Mar 22, 2019 9:14 pm
How about posting a short video clip
roymck
Post by roymck » Tue Mar 26, 2019 11:11 am
You could be right , pulled the timing cover off and yes there is a mark . It’s an early style cover and it’s rubbed on the casting or at least that’s what it looks like . Going to grind it down and refit it hopefully that will cure it.
nickm
Post by nickm » Tue Mar 26, 2019 12:28 pm
Excellent!
Hope it sorts it.
