Dashboard Inspirations ?
Has thanked: 268 times
Been thanked: 132 times
Post by MikeyBikey » Fri Mar 15, 2019 5:31 pm
My dash took a lot of work but I'm not sure. Fast road car will be the final result at the moment so want a bit of comfort / panache (although lets not forget its a scimitar) :roll:
However I am inspired by jags.
normal e type (albeit eagle version but its identical)
lightweight e type
lightweight e type.jpg (121.39 KiB) Viewed 2175 times
any ideas :?
Been thanked: 241 times
Post by AJL Electronics » Fri Mar 15, 2019 6:21 pm
I think the structure is good, but I would use 1/4" scrim foam on the silver bits and then black vinyl. That would look classy and contast nicely with the main colour.
Has thanked: 136 times
Been thanked: 135 times
Post by b.c.flat hat » Fri Mar 15, 2019 6:40 pm
Did yer make it or chop it out of summut?
Has thanked: 140 times
Been thanked: 995 times
Post by scimjim » Fri Mar 15, 2019 6:49 pm
I’d cover the alloy in black crinkle paint?
Post by MikeyBikey » Fri Mar 15, 2019 6:58 pm
The orange bit it is what sits underneath the original 5a plastic dash offering the main strength. I stripped / prepped and painted it. The aluminum plate is of my making
Has thanked: 154 times
Been thanked: 533 times
Post by Roger Pennington » Fri Mar 15, 2019 7:21 pm
I think I'm right in saying that only the earliest 3.8 S1 E-types had bare alloy dashes? That being so, a black vinyl covering would still be true to your inspiration (toggle switches as well!), but perhaps look more "finished"? (and cut down on reflections). Or crackle finish perhaps for a more "competition" look? In the end though, it's an aesthetic decision, and you're the one who will have to stare at it! :lol:
Has thanked: 142 times
Been thanked: 81 times
Post by efi_sprintgte » Fri Mar 15, 2019 8:20 pm
I recall comments of not being able to see easily due to glare? Something to consider on version 2.0
Has thanked: 31 times
Been thanked: 45 times
Post by Alan SS1 » Mon Mar 18, 2019 12:57 pm
i quite like it!
but as Mike will be driving it and string at it (well hopefully not, cos he'll be looking out window, not worrying about the Vauxhaul lump) :wink:
Post by AJL Electronics » Mon Mar 18, 2019 1:45 pm
Mikey, I can send you the scrim foam and vinyl if you want it, or I will cover it for you.
Rev Light
Been thanked: 30 times
Post by Rev Light » Mon Mar 18, 2019 3:41 pm
I am doing a similar thing, slow time, after having see Mikey's dash. I used some Halfords textured paint, but the sand colour is too bright for my tan interior. I will have to darken it a bit. I might go for a wood finish to the flat panel.
Following a trendsetter.
SE5a 'Fancier'
Post by AJL Electronics » Mon Mar 18, 2019 3:43 pm
How about hydrographic dipping?
Rev Light
Post by Rev Light » Tue Mar 19, 2019 2:44 pm
Andy, I am trying to decide of which material I am going to make the main panel out of. I was thinking of marine Ply, but there is a bend in it, so I am thinking of scoring the back to bend it and then to glass the back to hold the angle. I need to insert a small fillet next to vents also. Alloy might be the answer, but can that be dipped? Then there is the area in from of the heater, which I am going to keep, as it works fine.
Mainly been varnishing boats this winter.....
Mikey, what is the extra gauge that you have installed next to the vents? It is right in the area of the 'cut' for the bend. On purpose I presume.
SE5a 'Fancier'
Post by AJL Electronics » Tue Mar 19, 2019 3:04 pm
Alloy would be a good choice I think. Any material can be dipped so don't worry about that.
Pommy
Has thanked: 61 times
Post by Pommy » Tue Mar 19, 2019 7:56 pm
It never ceases to amaze me of the skill 'all of you' out there possess, I wish I had it, unfortunately not, so impressed.. Pommy
Pommy
1973 Se5a Auto
Has thanked: 365 times
Been thanked: 305 times
Post by CNHSS1 » Tue Mar 19, 2019 8:28 pm
I'm worried Mike has been abducted by aliens and replaced by a replicant. The old Mike used rmto rock up with gearboxes with no oil in and dashboards and footwells glowed with the light from dodgy connections in the wiring arcing nicely in the early morning mist.
Worrying about style based on E types??!! Nah can't be our Mikey, gotta be an imposter... :mrgreen:
