Wanted :SE5 seat in good order, or SE5a seat for recovering
Locked
Been thanked: 304 times
Post by AJL Electronics » Sat Mar 09, 2019 10:36 am
Anyone got a decent SE5 Driver's seat in black please? This can be identified by stitched flutes rather than heat welded. Otherwise one needing a retrim would be acceptable as would an SE5a seat in that case.
Also need some early black carpet pieces, thin hessian backed as OEM SE5.
Post by AJL Electronics » Wed Mar 13, 2019 9:19 am
Still need one please.
Been thanked: 427 times
Post by peter freeman » Wed Mar 13, 2019 10:17 am
MX5 is till the easier option to find Andy - or MGF ?
Post by AJL Electronics » Wed Mar 13, 2019 10:23 am
It is for a customer's car, to replace a damaged seat so it has to be an original. Luke seems to think he might be able to assist, just had a PM from him so here's hoping.
As an aside, the customer was horrified when I showed him how the seats are actually mounted in a 5! Given time I may design a frame that mounts to the middle outrigger on the 5 series.
Post by peter freeman » Wed Mar 13, 2019 10:39 am
Sometimes you just have to think that the original is not an option and a alternative is the only way to go - with a high back safer and more comfortable - good luck with your search.
Has thanked: 111 times
Been thanked: 164 times
Post by reliant-reviver » Mon Mar 18, 2019 7:02 am
MadMax in Reading has a pair of se5a seats for recovering if you are still in need Andy....
MadMax
Been thanked: 8 times
Post by MadMax » Wed Mar 20, 2019 10:00 pm
Pm sent
Max Benton
Reading, Berks
'Zeus' - Yellow SE5a
Locked
