fibreglass preparation
Been thanked: 91 times
Post by Old and Slow » Mon Mar 04, 2019 9:19 pm
I need to make some repairs to the transmission tunnel on the Sabre Six, it lifts out in two pieces so is now indoors and easy to get to.
I'm not worried about the cosmetic finish, as there's carpet stuck (well, unstuck actually) on the surface.
What's the best way to clean the existing surface so that new glass will stick? I'm planning to reinforce both the underside and the outer surface.
All suggestions and contributions gratefully received, with thanks in advance.
Philip
Been thanked: 297 times
Post by AJL Electronics » Mon Mar 04, 2019 9:37 pm
A wire wheel followed by thinners or acetone to remove the adhesive, then feather the edges with a stone wheel in an angry grinder. Lay up as required. No need to do both sides as the feathering should go down to the backside.
Last edited by AJL Electronics on Mon Mar 04, 2019 9:39 pm, edited 1 time in total.
ard126k
Been thanked: 41 times
Post by ard126k » Mon Mar 04, 2019 9:38 pm
I use an angle grinder. You just need to remove the surface dirt and oil until you're down to the mat. The grinder leaves a nice rough surface, coat it with resin then lay the new mat on.
Alex.
1971 SE5 1977 SE6 1982 GTC
TrevorG
Has thanked: 36 times
Been thanked: 54 times
Post by TrevorG » Tue Mar 05, 2019 10:25 am
One trick that I used for many years in mending fibreglass fairings on my race bikes was to drill a few holes around the keyed area, stick tape on the backside and when the resin is laid down they act as sockets for the resin plugs. It helped making sure that vibration never played a part in separating the join, or so it seemed.
manny
Been thanked: 25 times
Post by manny » Tue Mar 05, 2019 12:33 pm
Good day
on a similar note - i am attempting to use FG for the first time soon - will cardboard ( waxed ) be suitable as a mold? I am planning to make a cold air feed 'box'
Ta
Manny
scimmy_man
Been thanked: 45 times
Post by scimmy_man » Tue Mar 05, 2019 12:56 pm
for a quick job use clingfilm on crdboard as a former.
Post by AJL Electronics » Tue Mar 05, 2019 12:56 pm
As long as it is non porous and smooth, it will do. If the coating fails though, the cardboard will become part of the item. You can also use brown packing tape as release agent.
Has thanked: 354 times
Been thanked: 254 times
Post by Corky » Tue Mar 05, 2019 1:14 pm
As Andy says, packing tape works. That’s what I use all the time when filling gaps, or moulding little bits here and there.
It’s not much good if you want a nice finished surface though :lol:
manny
Post by manny » Tue Mar 05, 2019 1:54 pm
so on that premise - any sticky backed vinyl will do too?
Post by AJL Electronics » Tue Mar 05, 2019 2:13 pm
Not messy celery. Try it with acetone first.
Post by Old and Slow » Tue Mar 05, 2019 5:08 pm
I'm using clear plastic sheet from the front of a gift box thingy; once the resin is set I'm finding it peels away easily and leaves a super-gloss finish - far too "Cheshire" for my transmission tunnel, but it'll be hidden under the carpet anyway.
TrevorG - thanks for the "holes" tip - a good idea methinks.
Just waiting for some bits from Spalding Fasteners to fix everything in place, which raises the question - it looks like originally the tunnel uses self-tappers to screw directly into the floor (which looks to be about 3/4" thick fibreglass). Is this the standard fixing method?
Post by AJL Electronics » Tue Mar 05, 2019 5:12 pm
It isn't a good way. I would use Lokuts or Rivnuts. On a thin panel, Speednuts would have done.
Post by AJL Electronics » Tue Mar 05, 2019 5:13 pm
Actually on a thick panel, it would not really allow Rivnuts to be used either, so go Lokuts.
Post by Old and Slow » Tue Mar 05, 2019 5:20 pm
I've ordered "U"-clips for the self-tappers but they only slide over thin stuff, so now I'm a bit stuck. I'll look into some kind of Dzus quick release thingys I think.
https://www.merlinmotorsport.co.uk/s/bo ... -fasteners
Never nowt but what there's summat.
Sabreite
Post by Sabreite » Tue Mar 05, 2019 5:34 pm
If you have the original floor, it will be plywood covered in a layer of fibreglass as all Sabre Sixes, Sabre fours just had plain plywood floors. Fixing with self tappers was the original way of fixing the tunnel to the floor.
John
