battery cut off relay
rebel alliance
Been thanked: 52 times
Post by rebel alliance » Sun Mar 03, 2019 1:21 pm
would this be suitable to put inline on the battery earth cable
Been thanked: 231 times
Post by AJL Electronics » Sun Mar 03, 2019 1:36 pm
It probably would but why?
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 1:42 pm
Cheers...i reasoned that with a loom fire/short, by the time i stopped opened the bonnet and used a manual cut off it may be too late..With this its just flick a switch on the dash , couple of seconds at most
scimmy_man
Been thanked: 34 times
Post by scimmy_man » Sun Mar 03, 2019 2:26 pm
how much power would the starter draw?
probably more than 200 amp on a cold day.
would it weld the contacts closed?
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 2:49 pm
Reckon your right , found some 500 amp relays on ebay instead
scimmy_man
Post by scimmy_man » Sun Mar 03, 2019 4:39 pm
safer
Post by AJL Electronics » Sun Mar 03, 2019 4:40 pm
With the contacts held closed, it isn't such an issue, the thing that kills solenoids is switching high currents. I think it overkill though, you would be better improving the fusing arrangements in my opinion. That will also keep the important feeds like the clock and radio memories.
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 5:31 pm
Cheers the old loom scares me i just want a quick cut off just in case..Sorry Terry i can't get pm's to reply but the ebay starter / cut offs are around £12
Been thanked: 351 times
Post by peter freeman » Sun Mar 03, 2019 5:37 pm
You will still have some power around when the switch is off otherwise you will not be able to energise the relay - all be it wired just to the battery
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 5:45 pm
Thanks peter but it will only be one new wire from the battery through a switch to the relay operating coil everything else will be dead until i energise it
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 5:48 pm
Think how long it would take if you were in the outside lane of a motorway to get on the hard shoulder get out open bonnet and use a normal battery cut off....car be full of lucas smoke by then 😊
Post by AJL Electronics » Sun Mar 03, 2019 6:09 pm
Think how much easier it would be if the loom was saved by the simple addition of a few fuses. ;-)
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 6:11 pm
Your probably right but i would not know where to start 😊
Has thanked: 153 times
Been thanked: 27 times
Post by willholderogri » Sun Mar 03, 2019 6:12 pm
Its a good idea but it needs to be in the live feed
rebel alliance
Post by rebel alliance » Sun Mar 03, 2019 6:19 pm
Think the negative is easier ,stick the relay out the way ..i would not think it made any difference as long as the main battery power was cut ?
