15" alloy tyres
Geraint SabreGTCse5
15" alloy tyres
Post by Geraint SabreGTCse5 » Sat Mar 02, 2019 9:11 am
I have a set of 15 wolfrace alloys to fit to GTC... when I find enthusiasm to finish polishing them :oops: looking at the old tyres (in age not usage!) they are 205 60 15 ... and 195 65 15, the tyres on my middlebridge alloys fitted to a 5 are 195 65 15.
Any suggestions as to which would be the appropriate size to fit before I order something wrong....again?
thanks
Geraint
Sabre ti, se5, GTC, 6b.......
Has thanked: 140 times
Been thanked: 995 times
15" alloy tyres
Post by scimjim » Sat Mar 02, 2019 9:25 am
I have 205/60R15 on 8 ball, they’ll catch on full lock even with spacers. 195/65R15 are only a few mm different in height/radius just not as wide. I think I had 195/55R15 on my GTC with middlebrighe alloys but it was also slightly lowered.
oilrag
15" alloy tyres
Post by oilrag » Sat Mar 02, 2019 9:58 am
I have 195/60/15 on my GTC on middlebridge wheels,lowered 35mm . :w
1980 GTC : 1972 SE5A and a few more long gone but not forgotten. Ex Middlebridge Employee.(12/88-05/90) RSSOC 3140
Been thanked: 357 times
15" alloy tyres
Post by peter freeman » Sat Mar 02, 2019 11:23 am
I use rain experts 195x65x15 on our MB and 195x60x15 on the MB wheels fitted to our Coupe - just depends on which are closer to your original diameter I would think.
Geraint SabreGTCse5
15" alloy tyres
Post by Geraint SabreGTCse5 » Sat Mar 02, 2019 12:19 pm
thanks every one I don't really know what the original spec of the GTC tyre or its diameter is to be honest....every set of wheels I have here has a different size tyre on them ... the two handbooks I have quote different tyre sizes and 15" wheels wasn't an option back in the day!
Geraint
Has thanked: 154 times
Been thanked: 533 times
15" alloy tyres
Post by Roger Pennington » Sat Mar 02, 2019 12:23 pm
The one thing you haven't mentioned, which is quite important, is how wide the wheels are. I use 205/55VRx15 (Toyo Proxes T1R) on the Yellow Peril and I like them a lot. However, that's on 7 inch wheels. Originally I had them on Middlebridge wheels, which are 6 inch width - I would suggest that on that width 195 will be a better option (as was standard on the MB anyway), you'll get better control due to the more upright sidewalls. I could feel the difference when I chaged from 6in to 7in.
Geraint SabreGTCse5
15" alloy tyres
Post by Geraint SabreGTCse5 » Sat Mar 02, 2019 8:18 pm
Roger they are 6" wheels so it looks like 195 65 15 will need to be ordered
Geraint
Ollieoldbeard
15" alloy tyres
Post by Ollieoldbeard » Thu Apr 04, 2019 10:08 pm
Don't suppose anyone on here has some wide 14" tyre's knocking around, I need some 245/60/14"s ???
Very unusual I know
Has thanked: 142 times
Been thanked: 81 times
15" alloy tyres
Post by efi_sprintgte » Fri Apr 05, 2019 6:57 am
Very unusual I know
Try Revingtosh as he changed the wheels that were on his coupe.
Ollieoldbeard
15" alloy tyres
Post by Ollieoldbeard » Fri Apr 05, 2019 9:41 pm
Mucho Thanks
Where do you find Mr Revingtosh ?
(The link won't work for me)
15" alloy tyres
Post by scimjim » Fri Apr 05, 2019 10:06 pm
It’s not a link, it sends revingtosh a notification.
If you search for members, you’ll find his profile page, where you can email or PM from.
http://www.scimitarweb.co.uk/sgwrs/memb ... ile&u=7683
simmit
Has thanked: 127 times
Been thanked: 8 times
15" alloy tyres
Post by simmit » Sun Apr 07, 2019 8:58 pm
6"? Be sure because mostly, 15 Woolfies are 7" (I think) and require 10mm spacers at front (plus a little fettling of top wishbone corners) to give clearance. Just thought I'd mention it.
Geraint SabreGTCse5
15" alloy tyres
Post by Geraint SabreGTCse5 » Sun Apr 07, 2019 9:47 pm
thanks but mine are definitely 6.0 x 15
Geraint
Revingtosh
15" alloy tyres
Post by Revingtosh » Wed Apr 10, 2019 7:06 pm
Mine are 8J x 15. Small spacer needed up front.
