ScimitarWeb Developments
Can't register?
Has thanked: 73 times
Been thanked: 683 times
Post by philhoward » Fri Mar 15, 2019 8:52 pm
I have had the blank screen a couple of times but only on my phone (and possibly when I’ve had questionable service).
Notifications - check your spam filters first through a webmail (browser) portal if you use a client (Outlook/Mail etc).
Has thanked: 153 times
Been thanked: 1038 times
Post by scimjim » Fri Mar 15, 2019 10:32 pm
I had a blank screen a couple of times today at the farm and assumed it was a poor signal (although it’s not done that before) - pressed refresh and the page appeared.
TrevorG
Has thanked: 26 times
Been thanked: 32 times
Post by TrevorG » Sat Mar 16, 2019 1:06 am
Could still be internal memory problem due to complexity of page your computer needs to download. Webmaster may be able to help.
Post by scimjim » Sat Mar 16, 2019 8:22 am
Unlikely to be internal memory - we post in this sub-forum so that Ian can pick up a single thread rather than half a dozen PMs.
Been thanked: 380 times
Post by peter freeman » Sat Mar 16, 2019 10:25 am
I got all of the notifications this morning ( 8 of ) which included the ones I was missing - it this modern stuff -bring back the pigeons I say.
housemartin
Has thanked: 15 times
Post by housemartin » Mon Mar 25, 2019 9:41 pm
Uploading images no longer seems to work on firefox or chrome.
The message I get is:
You must enter your path and filename
It seems the browse button is not capturing the path and it cannot be typed in manually.
Any ideas
Dan
Post by scimjim » Mon Mar 25, 2019 9:59 pm
Chrome test
Hmm - works okay on my iPad through chrome?
Post by scimjim » Mon Mar 25, 2019 10:12 pm
Although I don’t use the browse button for pictures, only google drive, iCloud Drive or Dropbox.
Has thanked: 164 times
Been thanked: 555 times
Post by Roger Pennington » Mon Mar 25, 2019 10:43 pm
I posted one earlier today via Firefox, which was ok, though just as a double-check, here's another, also via Firefox on Win 10:
77MM Test 2019-03-20 -0219.jpg (131.47 KiB) Viewed 2621 times
(though note I did use drag'n'drop both times, as that's my normal way of doing it; I find it much easier).
This one was done using the browse button:
77MM Test 2019-03-20 -0064.jpg (117.17 KiB) Viewed 2621 times
Seems to be ok?
One thought - could it be that the path you used for your last upload, is now no longer present on the computer (ie you've disconnected a remote hard disk, unplugged a USB device, or detached from a network drive)?
Post by Roger Pennington » Mon Mar 25, 2019 10:59 pm
As a side issue Jim, I notice your image demonstrates the ongoing orientation issue with images from (primarily) phones and ipads, which expect to be re-oriented by the display device. To me it looks as though it's fallen over to the left, and needs 90 deg right rotation to fix it. It's easy enough to view it correctly, by right clicking on the image, then clicking "view image", which displays it correctly orientated. You then need to use the browser "back" button to return to the post. It's not the end of the world, but if there is a fix it would be nice, especially as such devices are becoming more common. :)
Post by scimjim » Mon Mar 25, 2019 11:15 pm
Hmm - the phone was upright when I took it?
Is this one sideways to you?
Post by Roger Pennington » Mon Mar 25, 2019 11:23 pm
Yes, I thought that was probably the case.
Your second shot looks the right way up :D
ALSE6
Post by ALSE6 » Fri Apr 05, 2019 12:57 pm
I am unable to bring up the web site www.scimitarweb.com I want to pay my subscription . Using Windows 10, Google Chrome.
Thanks...> Alan Mem: 4406
1976 SE6 GTE. 1976 SE6a GTE. 1971 MGB-GT. 1972 TR6. 1971 Ford Zodiac MK4 Executive
Post by philhoward » Fri Apr 05, 2019 1:15 pm
Does this work Alan: http://www.scimitarweb.co.uk/siop/index ... csj4caa015
That should take you straight to the Memberships section of the shop.
P.S. I'm using Chrome as well, but through Windows 7.
