SE5 chassis repair just arrived
Been thanked: 231 times
Post by AJL Electronics » Wed Feb 20, 2019 9:20 am
I have been cutting away the scrap metal on the offside and have had to go some way to find anything to weld to. I have also found holes in places that I wasn't expecting, like the tube that carries the rear jacking point etc.
Post by AJL Electronics » Wed Feb 20, 2019 9:30 am
Has thanked: 130 times
Been thanked: 951 times
Post by scimjim » Wed Feb 20, 2019 9:41 am
This is getting very close to needing the body off or some very big access holes cutting :shock:
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Wed Feb 20, 2019 9:46 am
Not good when the rear tube is holed...
Post by AJL Electronics » Wed Feb 20, 2019 10:44 am
The tube looks worse from inside. It is also full of crap and old underseal so my idea of driving in a smaller diameter pipe is not going to work well. I suppose that I could take out part of the external body and drive something in just so far. However, ignoring the owner's budget (if it were my car) I would complete the side rail etc both sides then lift the body to get at the rest of it. Not something that I think would float the owner's boat, but the way to get it just so as otherwise I will have to carve away most of the interior!
Post by AJL Electronics » Wed Feb 20, 2019 11:06 am
Apparently there is a sticky for body removal but I can't find it. Could someone point me to it please?
Post by philhoward » Wed Feb 20, 2019 11:51 am
http://www.scimitarweb.co.uk/sgwrs/view ... =32&t=6329
Now in the “How To Guides” section.
Post by AJL Electronics » Wed Feb 20, 2019 12:18 pm
Thanks Phil. James Holland said : "Bloody ages. Probably several days. 3-4. It allows for removing all shitty bolts and cutting others. Removing doors/glass/interior to make it lighter. Otherwise you would need some strong lifting hoists".
So now I am waiting for the owner to give me his further instructions because I can't do a body off job or even carve the interior about in his budget.
Post by AJL Electronics » Tue Feb 26, 2019 2:42 pm
New parts tacked in on the offside. I couldn’t do any more because the helmet batteries went flat on me. So now I have to wait for new batteries.
Post by AJL Electronics » Thu Mar 14, 2019 7:38 pm
Post by AJL Electronics » Fri Mar 15, 2019 2:20 pm
Slowly cleaning all the frilly bits away.
Bits of thin steel have clearly been used in the past to cover it up!
Post by philhoward » Fri Mar 15, 2019 6:01 pm
Looks like the return of the biscuit tin!
Post by gtcse8 » Fri Mar 15, 2019 6:11 pm
Get a Solar powered lid Andy, the Arc recharges it up, had mine 20ys and has never let me down.
Post by scimjim » Fri Mar 15, 2019 6:53 pm
Went to see this today and it’s a lot nicer than the pictures suggest. The rear tube, despite being holed, is generally solid. It obviously needs the standard B post base repair and Andy has done the side rails etc but it’s going to be a nice car I reckon.
Post by AJL Electronics » Fri Mar 15, 2019 8:14 pm
Well I am worried about it. That tube carries a lot of torsion from the suspension. Although I can plate the left and right sections it will still be weak and I can't easily do inside the bracket so it would be even weaker than the plated tube. My inclination is to replace the tube and bracket and then the body doesn't need to come off next year as the chassis will be full strength. However it isn't my money to spend of course.
I am advised that the tube isn't freely available and that I should cut up a scrap SE6 series propshaft.
Not sure where to go from here, my reputation and the owner's safety is at risk if I can't make a good job of it.
