SE5 chassis repair just arrived
Has thanked: 50 times
Been thanked: 258 times
Post by AJL Electronics » Mon Feb 11, 2019 10:15 am
Not seen one this bad before!
Post by AJL Electronics » Mon Feb 11, 2019 10:17 am
Post by AJL Electronics » Mon Feb 11, 2019 10:19 am
Has thanked: 153 times
Been thanked: 1050 times
Post by scimjim » Mon Feb 11, 2019 10:27 am
If that’s bad, the fuel tank/boot floor framework is usually worse!
rkclodhopper
Been thanked: 22 times
Post by rkclodhopper » Mon Feb 11, 2019 10:31 am
That thick layer of something appears to be hiding a few nasties, where do you start!
Richard
Post by AJL Electronics » Mon Feb 11, 2019 10:32 am
I will have another look. Hurts my knees crawling under there! It is 50:50 whether I will suggest a body off. Rear of the rails and jacking points not as bad as the front, but there is definitely some frilliness that will be difficult to get to.
Post by AJL Electronics » Mon Feb 11, 2019 10:34 am
On the main chassis rails, it appears to have been painted with silver Hammerite. Not sure if the rest is mud or underseal! As with the last one I did, it needs all the rot cutting away and then assess if there is anything left to weld to. I have my doubts!
Post by AJL Electronics » Mon Feb 11, 2019 10:46 am
Post by AJL Electronics » Mon Feb 11, 2019 10:47 am
The out of focus shot is a leaking fuel pipe. Just what you need when welding!
scimmy_man
Been thanked: 37 times
Post by scimmy_man » Mon Feb 11, 2019 10:49 am
I have repaired far worse, the main rails and the tubes holding the rear trailing arms are the bits that kill them.
Post by AJL Electronics » Mon Feb 11, 2019 10:49 am
Scotchloks and chocolate blocks. What joy!
Post by AJL Electronics » Mon Feb 11, 2019 10:51 am
Can't see the top rail of course, but looking at the supports, it doesn't look good.
Post by AJL Electronics » Fri Feb 15, 2019 7:51 pm
The owner has asked to go ahead with this chassis repair, so all being well it will come into the workshop early next week for the butchery to start. Pictures will follow as and when.
Datsundrew
Post by Datsundrew » Fri Feb 15, 2019 11:37 pm
My chassis was way worse than this, I really think to do it properly the body needs to be lifted.
Post by AJL Electronics » Mon Feb 18, 2019 12:45 pm
Fuel tank out for safety and inspection of the chassis rear. Surprising how good it seems to be. The fuel leak was down to it having no clips on it at all, just pushed over the spigot! It looks like the tank has been out before. A little tappity tap and the chassis is on the floor...
