EPAS on a SE5A
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Mon Jan 21, 2019 6:58 pm
hi just after collecting some info, i haven't even got my new Scimitar running yet but when i do i would like to fit power steering one day, if i don't my missus will never drive it :lol:
just wondered if anyone had done it before i'm thinking EPAS will be easier to do??? from what i have read no rack is available off the shelf and a SE6 rack would be wider?
i've got access to a vauxhall corsa column i can have but not sure if it will fit?
i don't mind a bit of re-engineering fabrication etc. thats all good fun to me :)
has anyone done this before? any pics? tips etc.
cheers :D
Has thanked: 127 times
Been thanked: 23 times
EPAS on a SE5A
Post by willholderogri » Mon Jan 21, 2019 7:31 pm
Many of us have done this mine is MGF look in the archives there is a lot of info there
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Mon Jan 21, 2019 7:44 pm
thanks 8) searching MGF makes it a bit easier and ive found this goood write up http://www.scimitarweb.co.uk/~nenoggins/EPAS.htm
see if i can find a cheap MGF column now :D
EPAS on a SE5A
Post by willholderogri » Mon Jan 21, 2019 8:03 pm
I'm the will in the article and Peter wrote the piece
Been thanked: 335 times
EPAS on a SE5A
Post by peter freeman » Mon Jan 21, 2019 8:20 pm
I will pm you more details - detail I put together for someone who wanted to fit the MGF system to a sabre but more or less the same info for a 5 fit.
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Mon Jan 21, 2019 8:59 pm
Thanks Peter i'd guessed it was you Will :D
any info is a help to me - it's not top of my list of to-do jobs but nice to have plenty of time to get the parts and when the time comes get the swap done
EPAS on a SE5A
Post by peter freeman » Mon Jan 21, 2019 9:02 pm
No1 on the job list is remove the drivers seat - I did the first car with the seat in place - makes life far more difficult
EPAS on a SE5A
Post by willholderogri » Mon Jan 21, 2019 10:07 pm
I will try and find my pics I have already promised to post them for another forum member
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Tue Jan 22, 2019 8:58 pm
well ive got myself a MGF EPAS steering column :D
might have to collect a bit of dust before i fit it but at least i have it now
EPAS on a SE5A
Post by peter freeman » Tue Jan 22, 2019 9:10 pm
Have you got the ECU steering wheel, plugs and cables as well and does he column have its bottom sliding piece with it.
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Tue Jan 22, 2019 9:47 pm
ive got the ecu and plugs but no steering wheel or nut - i think the bottom joint is there
i'll take a photo of what i have when i get some daylight
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Wed Jan 23, 2019 5:36 pm
i've only got half the sliding joint but everything else seems to be there
will i need the other half of the sliding joint?
mgf pas column.JPG (137.65 KiB) Viewed 878 times
EPAS on a SE5A
Post by willholderogri » Wed Jan 23, 2019 5:39 pm
Yes it's easier if you have it
EPAS on a SE5A
Post by peter freeman » Wed Jan 23, 2019 6:17 pm
Looks like you have most of the cable apart from the power ones but there is enough length left on the plug for you to just extend them. This is what I was left with after I had cut the bits off the column which were of no use.
CarlosVanDango
EPAS on a SE5A
Post by CarlosVanDango » Wed Jan 23, 2019 6:29 pm
yeah there is enough length to solder on new wires - shame i didn't get the sliding joint
it's even got the key with it but i don't think i'd be able to use it
