Rear drop links alternatives for SS1/Sabre
Has thanked: 357 times
Been thanked: 255 times
Post by Corky » Sat Dec 29, 2018 12:18 pm
I've been using the BMW E39 drop links on my small sports for a few years now, and have also tried out Roger's rose jointed home brew type. The problem with the BMW ones is that they're not a perfect fit and I've had a couple crack or work loose. So I decided to go on the hunt for something that has the M12 1.75 thread for the trailing arm (meaning that you don't have to pack out the thread to M10 or put a nut on the back).
I've come up with a Jaguar part, no. 18-16 060 0004
It has the correct thread for arm and a hole for a bolt to connect up to the ARB. Not sure if the hole is M12, but I'm thinking of ordering a couple to see if they fit.
Before I do, does anyone have access to one of these, or has anyone tried one in an SS1 ?
Another possibility is this from a Range Rover Sport https://www.ebay.co.uk/itm/123447397039. Just need to find a design that allows it to be tightened into the trailing arm, as this one doesn't look like you can get a spanner on it.
Both threads are M12 1.75
Post by Corky » Sat Dec 29, 2018 4:22 pm
I’m going to order a couple of these https://www.ebay.co.uk/itm/253350907777.
They look as near to OEM as anything else I’ve seen. Although a tad longer.
Has thanked: 109 times
Been thanked: 161 times
Post by reliant-reviver » Sat Dec 29, 2018 4:48 pm
Cut sleeve and weld. Sorted
Post by Corky » Sat Dec 29, 2018 4:56 pm
Some of the BMW ones wouldn’t take welding. They were made from papier-mâché or cheese, not sure which. I dare say with some of these ones of the right quality, welding could be the way forwards if they need shortening.
Post by reliant-reviver » Sat Dec 29, 2018 4:58 pm
They will need shortening. Unless you like sparks under acceleration or run stupid high spring rates (and like endless wheelspin off the line)
Has thanked: 178 times
Been thanked: 1228 times
Post by scimjim » Sun Mar 24, 2019 10:08 pm
Just ordered a set of the jag fronts - reckon a bolt through the top or bottom?
I haven’t measured the standard ones but they can’t be much shorter than 4” between centres can they?
old bean
Post by old bean » Sun Mar 24, 2019 11:47 pm
I spoke with Graham Walkers a few weeks ago and they were already looking at sourcing or having a batch of these knocked up. They might have them available by now but I've been too busy to ask them.
pauluspaolo
Post by pauluspaolo » Mon Apr 01, 2019 12:24 pm
Did you get these & if so did they fit OK?
Post by scimjim » Mon Apr 01, 2019 12:34 pm
Jag ones are M10 holes.
Post by Corky » Mon Apr 01, 2019 12:52 pm
Which part number Jim ?
All those I listed claimed to be M12.
I did buy some, but cannot for the life of me find them in the garage to check, or remember exactly which ones they were.
The Mitsubishi L200 ones are looking like the best bet, but come in different thread pitches depending on which brand you buy. https://www.ebay.co.uk/itm/Febi-BILSTEI ... SwjXNacqT9
Post by swoakes » Mon Apr 01, 2019 1:27 pm
On my ex Sabre I fitted Daewoo Nexus drop links identified by RR; he bought a box full cheap of EBay.
Not sure where I got them; possibly from RR :?:
Been thanked: 842 times
Post by philhoward » Mon Apr 01, 2019 1:39 pm
Weren't they fronts?
Post by scimjim » Mon Apr 01, 2019 1:39 pm
M12 studs but M10 holes the other end. The jag fronts you linked in the first post.
Post by swoakes » Mon Apr 01, 2019 1:48 pm
Just been checking my Sabre thread...it's not entirely clear but pretty sure I've done some rears; question is which car/front or back :roll: :lol:
Edit
Its the DET I fitted them too. BMW type http://www.scimitarweb.co.uk/sgwrs/view ... 30#p338765
Post by Corky » Mon Apr 01, 2019 2:49 pm
Ahh, so should be usable then?
Will the bottom hole drill out? Failing that, a bolt packed with a helicoil would be fine for the ARB fixing point.
