Essex idler pulley bearing
RodH
Has thanked: 21 times
Post by RodH » Sun Sep 02, 2018 8:40 pm
Hi everyone.
My Essex engine in my SE6A has a noisy idler pulley. I'm having trouble removing the pulley bearing.
I've removed the wire clip thingy and soaked the hole it was in with plus gas. Still no luck.
Is this bearing an interference fit or should it just slide out.
This may be a waste of time as I cant find a replacement. Only one for a ford 2.5 diesel 1985-2000, which looks the same.
This thread looks like an interesting compromise.
https://www.pistonheads.com/gassing/top ... &t=1642814
Has anyone any other suggestions.
Thanks,
Rod
82 GTC, 84 SE6b, 77 SE6a,
Saab 9000 2.3 FPT, 9000 2.0 lpt, C900 T16S Vert, C900i Vert.
Bond Equipe 2ltr convertible.
rebel alliance
Been thanked: 104 times
Post by rebel alliance » Sun Sep 02, 2018 8:59 pm
You have to remove the front cover and press it out from the back..I have seen the bearing on ebay,
rebel alliance
Post by rebel alliance » Sun Sep 02, 2018 9:03 pm
The pipe from pump to thermostat housing is missing in that picture..
RodH
Post by RodH » Sun Sep 02, 2018 9:15 pm
Thanks for the reply.
I need to source one before I remove the timing cover.
I cant find them on ebay. Perhaps I'm not describing it correctly. "Ford Essex idler bearing",
"Ford Essex fan bearing" shows two that look the same but are listed for the 2.5 diesel. If that is an essex based diesel great but I don't want to risk £30 on the off chance.
Rod
Has thanked: 132 times
Been thanked: 875 times
Post by philhoward » Sun Sep 02, 2018 9:21 pm
