Trunnion bolt torque
Has thanked: 164 times
Been thanked: 551 times
Post by Roger Pennington » Wed Nov 04, 2009 12:29 pm
Yep, that's it! the bushes stay fixed with the wishbones, and the trunion+bolt+sleeves all behaves as a single assembly, so when you move the upright, the whole assembly rotates in the bushes. That's why it's good to lubricate the bushes generously when you put it together, and even better if you do the lower wishbone grease nipple mod so that you can grease them at intervals.
cheers
JoeySully
Been thanked: 32 times
Post by JoeySully » Wed Nov 04, 2009 12:37 pm
I fitted the trunnion last week, I had read the sticky before i did it and its been baffling me all week how the hell the mechanism would work if the bold cannot move which mine did but only when the trunnion moved. So i have it on correctly then. happy days. Will get the other one done on saturday.
Scim6
Re: Trunnion bolt torque
Post by Scim6 » Wed Aug 25, 2010 6:43 pm
The trunnion that I have just assembled seems to work in the correct way but it is quite hard to turn it and it will definatly not fall under its own weight. Is this a big issue? I am pretty sure that as long as it works in the correct way then the stiffness will not matter too much as the weight of the car will make this neglectable.
steve
1977 SE6A - First car
Has thanked: 152 times
Been thanked: 1038 times
Post by scimjim » Wed Aug 25, 2010 7:04 pm
something is almost certainly assembled incorrectly or needs slight fettling. it may wear in with a little use but it's much better to be free to begin with IMHO
Scim6
Post by Scim6 » Wed Aug 25, 2010 8:50 pm
What do you think the problem could be? As far as I can see it is correct and through the greese nipple holes I can see that the bushes arn't moving. There is no resistance when I move the bolt without the nut on. and the torque is pretty close to that stated. Thanks for the help
steve
Scim6
Post by Scim6 » Fri Aug 27, 2010 1:18 pm
are the bush kits from qrg known to be good or could they possibly be the wrong length? The bushes and tubes are the same lengths as the ones on the passenger side and that is correct and easy to move, is there I should look out for on assembly a certain order or something?
JoeySully
Post by JoeySully » Fri Aug 27, 2010 1:59 pm
I had a tight fitting trunnion, well it was so tight that it couldn't move at all after assembly, so used my old top hats as they were in good condition but the flat part was a bit skinnier. I also cleaned down the sides of the wishbone eyes to remove any paint that I had put there from painting.
Loosen the lower wishbone bolts from the lower bracket too so that the trunnion bolt lines up square with the wishbone eyes.
If you are still getting a tight fit then use a bit of sand paper to make the flat part of the top hats a bit skinnier, or a lathe would be easier if you have access to one.
This is what I did and may not be the correct procedure ;)
Is your trunnion new ?? if not then it may have been loose before and worn the brass down although this might not cause a tight fitting
Scim6
Post by Scim6 » Fri Aug 27, 2010 6:27 pm
it is a new trunnion as the old bolt had siezed inside, its just wierd that the same kit works fine on the other side. I did the same as you and made sure that the eye faces were clean bare metal. I will give sanding them a go. thanks
steve
Scim6
Post by Scim6 » Wed Sep 08, 2010 4:00 pm
the sanding worked. how do you get the greese seal in on the rear of the front 2 bearings?
JoeySully
Post by JoeySully » Wed Sep 08, 2010 4:03 pm
Scim6 wrote:the sanding worked. how do you get the greese seal in on the rear of the front 2 bearings?
That needs a bit more explanation I think??? Are you talking about trunnions or wheel bearings?
Scim6
Post by Scim6 » Wed Sep 08, 2010 6:36 pm
sorry, the greese seal on the wheel bearings, it is a very tight fit is there any special method?
Scim6
Post by Scim6 » Fri Sep 10, 2010 3:03 pm
still no luck, there must be a way to do it
Has thanked: 73 times
Been thanked: 678 times
Post by philhoward » Fri Sep 10, 2010 3:17 pm
Silly question - they ARE SE6 wheel bearings, aren't they?
Scim6
Post by Scim6 » Fri Sep 10, 2010 4:58 pm
yes do you know what I mean or is my desrription terrible :oops:
Post by Roger Pennington » Fri Sep 10, 2010 5:10 pm
I must admit I'm having trouble understanding exactly what the problem is. Could you please describe the grease seal in a bit more detail, and exactly where it's causing a problem?
thanks,
...Roger
