small sports chassis weight
Has thanked: 153 times
Been thanked: 1043 times
Post by scimjim » Fri Jan 04, 2013 5:31 pm
CNHSS1 wrote:Dunno if you have a scale suitable, but could you weigh a chassis? Maybe a spring type susepnded from an engine crane?
FINALLY managed to do this today and the results are:
non-galv: 97.5 Kg (minor bits fitted - 2 x CVH rubber engine mounts, 3 x rubber diff mounts, 4 x door hinges, bump stops)
galv: 105.3 Kg (only bump stops fitted) - edit, note below - this is a retro-galv without Ti engine mounts.
it was a real struggle, so only accurate to within a couple of Kg either way.
Has thanked: 32 times
Been thanked: 50 times
Re: small sports chassis weight
Post by Alan SS1 » Fri Jan 04, 2013 7:19 pm
Two Questions
1 is the non galv one ferrous oxide free?? :-)
2 how many weight savings are in above non galv!!
Make that three Qs
3 how much weld on non galv!
Seriously 7 or 8kg is fair bit extra from the Zn :shock: (or did Reliant increase the overall gauge of the later chassis with the need for the Ti)
Has thanked: 166 times
Been thanked: 557 times
Post by Roger Pennington » Fri Jan 04, 2013 7:25 pm
Alan SS1 wrote: Seriously 7 or 8kg is fair bit extra from the Zn :shock: (or did Reliant increase the overall gauge of the later chassis with the need for the Ti)
I don't know if there were any change to the gauge, but the galv chassis did come with both engine mounts, which presumably would add a bit to the weight?
Post by scimjim » Fri Jan 04, 2013 7:27 pm
Good point about the galv one being ferrous free - it's actually a Reliant retro-fit item and I can guarantee there is some internal corrosion because someone has bodged the earthing point and it cracked, so I ripped it out and can see inside (will try and take some pics later) - it does however mean that it doesn't have the additional Ti engine mounts.
sorry - don't understand Q2 :oops:
the non-galv has been repaired (poorly) along the sills and a few inches up the A/B posts both sides as well as the NS bend where they crack by the exhaust downpipe.
Galvanising is generally accepted to add 7 or 8% weight to a chassis - the above works out to exactly 8% I think the gauge is identical.
tony.idle
Been thanked: 56 times
Post by tony.idle » Fri Jan 04, 2013 7:28 pm
The time honoured method is to hold the spring balance in one hand and lift up & hook the item to be weighed onto it with the other. Where's the struggle? :mrgreen: :mrgreen:
Tony
RSSOC 2332 since 1981
Post by scimjim » Fri Jan 04, 2013 7:33 pm
a spring balance would have been a start Tony :-)
turns out that the scale on the sheep pen outside, is an integral part, so I couldn't use that - as it was a rare day that I had an assistant that could lift a chassis (I don't want to kill poor Chris off :-)), we used the digital bathroom scales (that I bought to weigh everything as I took it off G97 and lightened). Although apparently good for 150 Kg, we obviously had to balance the chassis quite accurately to get a figure :-)
Post by Alan SS1 » Fri Jan 04, 2013 7:38 pm
sorry Q2 :oops: toooo tangential
what I meant was how many fresh air sections were there (as in sections of sill that you can poke fingers through)
if it is any consolation the 'remains' of mine weighed in at around 100kg at local breakers yard, that was with fresh air and offset by the extra weight from corrosion. what EOL form? :wink:
bathroom scales 150kg jeeze thats > 350 lb that ??? Stone :shock:
USA bathroom scales? :wink:
PS I have a DIFF reinforcing plate here if it is required approx 2mm thick mild steel and plastic coated (well most of it is)
Post by scimjim » Fri Jan 04, 2013 7:58 pm
ah - the sills had been repaired - only small holes showing but it was repaired without removing or cutting the tub, so the top inner joint isn't actually welded :shock:
It's from the car that I bought to repair G97 when DJ rolled it. The chassis turned out to be much better than advertised (I only paid £75 :-)) and I got a pair of QRG galv sills with a free car I collected a few weeks later :-)
I have one of those diff mounting repair plates too :-)
http://www.scimitarweb.co.uk/sgwrs/view ... diff+crack
Has thanked: 420 times
Been thanked: 352 times
Post by CNHSS1 » Fri Jan 04, 2013 8:29 pm
Great work Jim, i owe you a pint or 4 next time we meet!
Did it have the front shock mounting coss beam?
By the time you add the front armature, rear armature and largely unstructural tub, ill bet you will double the 100kg.
A Locost 7type is about 75kg, and a race spec 7type (Caterham superlight/bec westfield etc) 65 kg
Post by scimjim » Fri Jan 04, 2013 9:35 pm
no crossmember, no brake pipes, nothing unless listed.
Rear armature is 8Kg, Front armature is 15Kg, Headlights inc motors etc are 9.6 Kg the pair, 6.8 Kg for the standard CVH rad and fan (inc crossbar) - there's 40 Kg straight away! I reckon I've got that down to 10Kg on G97?
nearly all of the weight of the tub is in the windscreen and surround as you know, I will weigh a body tub sometime too, guesstimate (from lifting it off the chassis today) is around 45 Kg :-)
scimmy_man
Been thanked: 37 times
Post by scimmy_man » Fri Jan 04, 2013 9:36 pm
non-galv: 97.5 Kg
sounds heavy, I remember picking one up at the factory, and asking why they didnt galv them, this would be very early in production life.
tony.idle
Post by tony.idle » Sat Jan 05, 2013 12:41 am
scimjim wrote:a spring balance would have been a start Tony :-)
A friend bought a set of (what we assumed were) sheep pen scales at an agricultural auction. He was going to use them to measure hovercraft thrust. It turned out that the (numeric) scale was meaningless - apparently because there must have been a lever ratio between sheep & scales.
Tony
Post by scimjim » Sat Jan 05, 2013 11:41 pm
Front crossmember is 2.3Kg
Bare body tub is 43.1Kg - over 20Kg of that is the windscreen and surround.
Pedal box inc servo & MC is 7.5Kg
Has thanked: 163 times
Been thanked: 153 times
Post by b.c.flat hat » Sun Jan 06, 2013 12:01 pm
Just had a thought Jim, did CH ask you t'weigh him as well! All this talk of "bare body", "tub" and the like derailed my train o' thought!
Or 'as 'e got weight shift ideas for the peddler!
Post by Roger Pennington » Sun Jan 06, 2013 1:48 pm
For info, thread now stickied :)
