Bogging at 4000 rpm
Bogging at 4000 rpm
Post by scimjim » Sat Jan 19, 2019 6:27 pm
Dear god - what a bodge!!!!
Rip the lot out and do it properly :D
Bogging at 4000 rpm
Post by DARK STAR » Sat Jan 19, 2019 6:34 pm
I'd love to, but what should it look like?
Bogging at 4000 rpm
Post by scimjim » Sat Jan 19, 2019 6:43 pm
It’s not standard, so it can be whatever you want it to look like - but 6 jubilee clips and random bits of rubber pipe and metal tubes is just asking for trouble :D
Bogging at 4000 rpm
Post by DARK STAR » Sat Jan 19, 2019 6:54 pm
The tank is standard ...
I suppose I'll just have to take the blue connector off and see if I can get one that fits with a 12 mm (or better still 8 mm) outlet.
Serious perusal of Demon Tweeks catalogue to follow.
Bogging at 4000 rpm
Post by scimjim » Sat Jan 19, 2019 6:57 pm
If the blue connector has a barbed end under that hose, just fit new 12mm pipe (or whatever size it is), then a single step-down to 8mm which is presumably what the filter is?
Bogging at 4000 rpm
Post by DARK STAR » Sat Jan 19, 2019 7:09 pm
The first length of pipe is 16 mm, that's the problem (well, one of them).
Yes the filter is 8 mm (Sytech), the original was 12 mm (Ford), the origin of the 16 mm I don't know :roll:
So, is there such a thing as 16 mm petrol pipe ?
Motolab
Petrol problems
Post by Motolab » Sat Jan 19, 2019 7:12 pm
DARK STAR wrote:
Sat Jan 19, 2019 5:10 pm
I
Now I am nudged, it seems also that the blue fitting is a hydraulic connection.
Why it was installed in this manner is a mystery.
The upper nut on the hydraulic fitting is 26 mm across flats, the lower one is 24 mm, these are probably not metric
Well, i can think of one reason.....
If it is an unf/unc size thread they might have gone to a Harley Davidson shop, for some parts when they needed some..
I believe they sell these parts for connecting the oil tank to the engine (dry sump engines)
Harold, currently driving:
Scimitar se6a '76
Saab 9-5 Aero estate '02 stage 3, 300bhp,420Nm
Triumph speedtwin '49, Sunbeam S7 '48, BSA B33 '54 & M21 '40 , Moto Guzzi LM2 '79, BMW R51/3 '51
www.motolab.nl
Bogging at 4000 rpm
Post by scimjim » Sat Jan 19, 2019 7:42 pm
16mm (5/8”) is pretty common in fuel systems. I think the late small sports fuel tank outlet is that size for instance (going to an 8mm fuel pump inlet).
Bogging at 4000 rpm
Post by efi_sprintgte » Sat Jan 19, 2019 8:28 pm
My XR4x4i had 16mm fuel tank to fuel pump, then 8mm outlet from the fuel pump to the rest of the system.
Bogging at 4000 rpm
Post by DARK STAR » Sat Jan 19, 2019 9:05 pm
So a 16 mm / 8 mm reducer is a standard item ?
I'll get my Demon Tweeks bible out tomorrow.
Bogging at 4000 rpm
Post by philhoward » Sat Jan 19, 2019 9:35 pm
M16 thread maybe - but 5/8”/16mm is huge for a fuel outlet? Normally 12mm from a tank to pump?
Just had a google and 16mm is used :shock: - just haven’t come across anything that big myself.
Bogging at 4000 rpm
Post by scimjim » Sat Jan 19, 2019 10:55 pm
They’re a couple of quid delivered - and nylon, so not affected by ethanol.
GavinR
Petrol problems
Post by GavinR » Sun Jan 20, 2019 12:00 am
It's not a hydraulic fitting - its a Goodridge alloy fuel fitting for a push on hose
https://www.advantage-motorsport.co.uk/ ... se+Fitting
Dash 10 JIC would be for a 5/8" hose and the thread is equivalent to 7/8” - 14 UNF
GavinR
RSSOC Member 3513
1971 SE5a
1970 SE5 Project
Petrol problems
Post by DARK STAR » Sun Jan 20, 2019 6:28 am
Thanks Gavin, that gives me something positive to look for.
Bogging at 4000 rpm
Post by DARK STAR » Mon Jan 21, 2019 6:42 am
Exactly as Gavin said, the blue bit is a dash 10 JIC (why 10 I wonder).
Now, having spent an hour and a half removing the damn thing and another hour perusing the Goodridge catalogue, it appears that connectors of 7/8 inch are only available with 16 mm (5/8 inch) outlet :roll:
At the outlet end of the connector the other 'nut' is smaller but is impossible to unscrew, I have nearly pulled my vice off the bench trying.
So I need to find some 16 mm hose and a 16 / 8 mm adapteur or do it as before with two reducers.
Or perhaps I can screw something else on the fuel tank exit ... I'll see if I can unscrew the remaining 'nut'.
Can I repeat my first appeal, what is the nature of this tank exit, and where can I get 16 mm fuel hose :?:
Return to “Middlebridge”
