SS1 1800 Ti No Sparks
Been thanked: 118 times
Post by gtcse8 » Mon May 20, 2019 7:32 pm
RonPerry wrote:
Mon May 20, 2019 5:11 pm
new part sourced
:wink:
7 left now
PeteMac
Has thanked: 29 times
Post by PeteMac » Mon May 20, 2019 7:36 pm
That pesky optical sensor again!
Good to hear the car's up and running. :)
1987 1800Ti
(previous 1975 SE5a, 1968 GT)
Has thanked: 58 times
Been thanked: 620 times
Post by philhoward » Mon May 20, 2019 8:17 pm
These optical sensors - don’t suppose they’re used in a Stanadyne diesel pump are they?...
Post by gtcse8 » Mon May 20, 2019 8:23 pm
Doubt it Phil
Not heard about it in my research.
Diesel are Compression Ignition, not Suck Squeeze Bang Blow.
Post by philhoward » Mon May 20, 2019 8:27 pm
I’ve got a GM 6.5TD in the motorhome which has partial electronic control of the diesel pump with “an” optical sensor inside it (and I’ve had a strange cutting out issue). Just wondered if it might be the same one as I suspect diesel timing needs to be pretty good.
Post by gtcse8 » Mon May 20, 2019 9:00 pm
The Nissan CAS uses TWO eyes and cutouts in the "Disc".
One tells the ecu TDC and the other reads 360 degrees for firing and injectors.
Been thanked: 240 times
Post by AJL Electronics » Mon May 20, 2019 9:33 pm
A sillyscope would show up issues there would it not?
Post by philhoward » Mon May 20, 2019 9:35 pm
If I could make it misbehave again, yes...
RonPerry
Post by RonPerry » Tue May 21, 2019 2:25 pm
Woo Hoo. MOT passed with no advisories. Good to be back on the road!
Post by philhoward » Tue May 21, 2019 3:20 pm
Those are Saab engines Mikey was referring to. About 350bup in stock internals I think.
Post by gtcse8 » Tue May 21, 2019 7:06 pm
Well done Ron
