Sill body mount issues.
Has thanked: 31 times
Been thanked: 47 times
Post by Alan SS1 » Fri Apr 19, 2019 7:24 pm
scimjim wrote:
Fri Apr 19, 2019 4:14 pm
120mm on a non galv chassis, a galv (CVH mounts only) chassis, a galv Ti chassis and a galv mk1.5 Sabre chassis.
is that not 'all' ? , or only the selection that you have? :wink:
I see that the holes in tub are pretty 'generous' so should have been able to hit the mounting-hole somewhere?
but you will need a HUGE washer?
Has thanked: 143 times
Been thanked: 1008 times
Post by scimjim » Fri Apr 19, 2019 8:00 pm
That was the bare chassis I have in the workshop (although the Sabre isn’t actually bare and I forgot that the remains of batmobile are outside).
MartinSS1
Post by MartinSS1 » Fri Apr 19, 2019 8:29 pm
Brilliant, that's great, thanks. I presume my donor sills have had a bad repair at some point and gained 10mm! I'll check my body, but if I have 3 holes, I'll just keep the 2 bolt mounts and lower them a bit.
