small sports chassis weight
Has thanked: 22 times
Been thanked: 35 times
Re: small sports chassis weight
Post by nickkeyser » Sun Jan 06, 2013 2:52 pm
To help pull this all together I've just grabbed these from Jims racer build thread;
scimjim wrote: NOSECONE - 6.4
LIGHT PANEL - 2.5
BONNET - 16.5
FRONT WING OUTER - 3.3
DOOR (E/W, E/M) - 16.8
REAR WING (INC INNER) - 4.5
REAR DECK - 2.5
BOOTLID - 11.8
REAR LIGHT PANEL INC LIGHTS - 5.3
FRONT ARMATURE - 15
FAN & BAR - 2.3
RADIATOR - 4.5
BATTERY (HB063) - 11.1
HEADLIGHT (INC MOTOR & BRACKETS) - 4.8
FRONT INNER WING LH - 3.3
FRONT INNER WING RH - 3
BLOWER MOTOR - 2.2
HEATER UNIT - 5.3
ALTERNATOR - 3.8
ELECTRICAL LOOM (WITHOUT SWITCHES) - 5.8
ROLLBAR - 7.3
REAR ARMATURE - 8
BOOTLINER - 13.3
FUEL TANK - 9.5
KN ALLOY WITH PIRELLI P6000 - 13
And, the Protection & Performance 6 point roll cage;
CNHSS1 wrote:ccomplete cage weighs 42.5kg
Has thanked: 130 times
Been thanked: 949 times
Post by scimjim » Sun Jan 06, 2013 8:19 pm
b.c.flat hat wrote:Just had a thought Jim, did CH ask you t'weigh him as well! All this talk of "bare body", "tub" and the like derailed my train o' thought!
Or 'as 'e got weight shift ideas for the peddler!
My scales only go to 150Kg :mrgreen: I suspect he's going on a crash diet and fitting the seat centrally above the Bellhousing :-)
Post by scimjim » Sun Jan 06, 2013 8:24 pm
nickkeyser wrote:To help pull this all together I've just grabbed these from Jims racer build thread;
That's from my excel spreadsheet Nick, I'll update it with the latest figures and add to both threads periodically. I weighed a standard diff last night - but must have had a blonde moment because they certainly aren't 2.6Kg :oops:
Post by nickkeyser » Sun Jan 06, 2013 8:26 pm
Thank you for sharing the weights - they're all on my spreadsheet too ;)
Diffs 26kg more like!
When I add up everything I've binned, my car should be lighter than it is! All those little bits n bobs add up to a lot as well.
Has thanked: 331 times
Been thanked: 265 times
Post by CNHSS1 » Sun Jan 06, 2013 9:04 pm
Ho ho ho Boys, cheers for the fat jokes ;-)
I can lose weight, you thin guys cant go sub 65s let alone sub 60s at Curbs.
When your fast, then you can bring with the jibes ;-)
Post by scimjim » Sat Jan 12, 2013 10:34 am
I've only just managed sub 75 at Curbs :-) (77 odd in a standard SE5, 76 odd in a standard SS1, 74 odd in the Ti with a leaking boost pipe in the pouring rain!)
Standard diff inc Reliant cradle is 23.9 Kg
old bean
Post by old bean » Wed Jun 05, 2013 11:34 pm
Has anyone weighed an entire SS1 in either CVH, Ti, SSt or Sabre format? I've read various accounts of SS1's weighing in from 860kg in base spec up to nearly 1000kg for the Sabres and wondered what the different models actually weigh?
I'll get my Ti weighed at the local scrap yard as they've got a drive on weigh bridge, will post up the results when I have them.
Has thanked: 33 times
Been thanked: 92 times
Post by swoakes » Wed Jun 05, 2013 11:52 pm
My Sabre Ti was weighed by Steve Cork at 920 kg. I would expect an SS1 to be a bit lighter?
td99
Been thanked: 25 times
Post by td99 » Thu Jun 06, 2013 9:20 am
My Ti weighed in at 930 kg (incl heavy roll-bar, spare wheel).
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Has thanked: 137 times
Been thanked: 508 times
Post by Roger Pennington » Thu Jun 06, 2013 11:20 am
old bean wrote:Has anyone weighed an entire SS1 in either CVH, Ti, SSt or Sabre format? I've read various accounts of SS1's weighing in from 860kg in base spec up to nearly 1000kg for the Sabres and wondered what the different models actually weigh?
Over the last few years, as the Club has been operating a power/weight handicap system, all the compies will have weighed their cars for that purpose, and submitted the results. So there must be weights floating around somewhere - try a search in the competition section, I've got a vague feeling I remember seeing something there?
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Thu Jun 06, 2013 12:16 pm
swoakes wrote:My Sabre Ti was weighed by Steve Cork at 920 kg. I would expect an SS1 to be a bit lighter?
Your car has had the several kilos of lead (might be zinc) lined soundproofing removed though...
Post by CNHSS1 » Thu Jun 06, 2013 12:17 pm
Ti's in standard form tend to vary between 920-980kg, dependant on wheels fitted, roll bar, hard/soft top etc. None drop below 900kg.
CVHs are lighter, but the ones that have competed in recent times have all been lightened to compete in ModProd, so their figures aren't accurate for a standard car (Nick Keyser, Jim Keyser for example)
Non galv cars are always lighter as only 70% of the chassis still exists in metallic form the rest is a red dust trailing behind as the car drives... :lol:
(apologies R-R, only kidding)
Its surprising the differences in component weights that make a big difference. Add a Ti foam spoiler, 15" wheels, change the seats, add hardtop with glass sunroof and the figures vary by 50kg easily.
std seats are mega heavy, especially as they aren't the last word in comfort!
Post by CNHSS1 » Thu Jun 06, 2013 12:21 pm
Sabres seem to vary a lot too. The body thickness isn't uniform as hand lay up, where as at least SS1s are pretty uniform in the panel weights.
My SST was pretty thick GRP in sections but not others, depends if laid up Monday or Friday, and by Fred or Joe I guess :lol:
add in leccy mirrors, leccy windows and even door card furnishings and you can shave or add a good 20kg imho.
I know Chris 'Statto' Eades swapped door cards and window mechs form his parts bin onto his old CVH car, all added up to a weight saving within the regs
Post by philhoward » Thu Jun 06, 2013 12:25 pm
I couldn't believe the weight in the door trims on a Sabre - they weigh a ton compared to the svelte foam cards on an SS1..
