Useful Torque Wrench Settings
Re: Useful Torque Wrench Settings
Post by toomanysabres » Tue Nov 12, 2013 11:42 am
SI units were introduced in 1960. You have had 52 years to get used to them. :mrgreen:
http://en.wikipedia.org/wiki/Internatio ... m_of_Units
Post by philhoward » Tue Nov 12, 2013 11:44 am
Whats's wrong with using a 9.81 correction factor between kg and Newtons? :mrgreen:
0.454 kg in a lb
0.3048 feet in a metre
Easy peesy...or just look at the other scale, of course ;) I'd say GW owe you a set of main bearing bolts though :w
Post by toomanysabres » Tue Nov 12, 2013 11:59 am
When I was at Sperry Univac. My mate Keith and I re-invented the world of measurements by changing the derived units for a new system based on a different base. So instead of the Metre, Kilogram & Second (MKS) ours were the FFF system where the basic units were the Furlong, Furkin & Fortnight. :mrgreen:
Now a fortnight is quite a long time in anybodies money, especially so when we were dealing with computer hardware. So we decided a practical day to day unit of time was to be the femptofortnight (10^-15 of an F) this evaluates to 1.2nS so quite useful really :D
We also came up with a unit of currency bigger than a penny so more useful. It was the nanofax. 10^-9 of the reserves of the Halifax Building Society. - about thruppence.
Post by scimjim » Tue Nov 12, 2013 2:03 pm
Roger Pennington wrote:
AJL Electronics wrote:Looking again, perhaps I didn't read that right? The red figures are for the Cologne?
Yes, that's how I'd read it - the red figures are Cologne.
However........ that's not all. I don't have any direct experience of the cologne, but I do have the Cologne Supplement in my collection, so I had a look in there. The figure given for the mains is indeed 90 - 104 as listed, *but* the Cologne engine figures in the supplement are given in Newton/metres not foot/pounds and if the online converter is right, 90 - 104 Nm equals 66.4 - 76.7 lbs/ft :(
Looking at a few other figures, I think that may be true for all the engine figures?
Wow - that useful torque settings is a straight copy from the GW parts list which makes it around 20 years old - and no-one's ever noticed!!
I'll rewrite it now Roger.
Post by scimjim » Tue Nov 12, 2013 2:52 pm
Tightening Torques - 2.5/30 Essex engine (SE4a-SE6a) - lbft (Nm)
Main Bearing Bolts 55-60 (74-81)
Big End Bolts 25-30 (33-40)
Cylinder Bolt Heads 81-86 (109-116)
Flywheel Bolts 45-50 (61-67)
Inlet Manifold 12-16 (16-21)
Oil Pump 12-15 (16-20)
Crankshaft Pulley 40-45 (54-61)
Camshaft Gear Bolt 40-45 (54-61)
Tightening Torques - 2.8 Cologne engine (SE6b & GTC) lbft (Nm)
Main Bearing Bolts 66-67 (90-104)
Big End Bolts 19-24 (26-33)
Cylinder Bolt Heads (hex)
stage 1: 30-33 (40-45)
stage 2: 41-52 (55-70)
stage 3 (after 10 mins): 70-85 (95-115)
stage 4 (after warm up): 70-85 (95-115)
Flywheel Bolts 47-52 (64 to 70)
Inlet Manifold 21-25 (28-33)
Oil Pump 10-13 (14-17)
Crankshaft Pulley 85-96 (115-130)
Camshaft Gear Bolt 31-37 (42-50)
NOTE - 2.8 figures taken from Ford Granada Haynes manual
Tightening Torques SE5-GTC - lbft (Nm)
Upper Wishbone to Frame 22-24 (29-32)
Tie Rod Lever to Vertical Link 32-35 (43-47)
Upper Ball Joint 35-50 (47-67)
Stub Axle to Vertical Link 50-65 (67-88)
Upper Wishbone to Fulcrum Bracket 26-40 (35-54)
Trunnion Bolt 50-65 (67-88)
Radius Arm Bolts 110-120 (149-162)
Cantilever Arm Pivot 18-21 (24-28)
Watts Linkage Arm 50-55 (67-74)
Drive Flange Bolts 30-35 (40-47)
Rear Axle Shaft Nut 120-130 (162-176)
tony.idle
Post by tony.idle » Tue Nov 12, 2013 4:07 pm
toomanysabres wrote:When I was at Sperry Univac. My mate Keith and I re-invented the world of measurements by changing the derived units for a new system based on a different base. So instead of the Metre, Kilogram & Second (MKS) ours were the FFF system where the basic units were the Furlong, Furkin & Fortnight. :mrgreen:
Sperry Univac obviously didn't keep you fully occupied then :mrgreen:
Tony
RSSOC 2332 since 1981
Oldtimer
Post by Oldtimer » Thu Jan 15, 2015 7:22 pm
Checked out the Chevete manual for the torque figures for brake calliper to steering arm stub axle when I was putting the callipers back on my Sabre. Wow! 70 lbft or 100NM I don't believe it! On checking my original Reliant 6a factory workshop manual for the same dimension bolts it was 50 lbft Whew nearly got me that time Gremlins!
Bill
Post by Roger Pennington » Fri Jan 16, 2015 1:02 pm
Aren't the Chevette ones 12.9 spec, so presumably have a higher torque figure?
Post by scimjim » Sat Jan 17, 2015 11:10 am
Even though the caliper and upright aren't from a Chevette, I think I use 70lbft on the small sports?
Oldtimer
Post by Oldtimer » Thu Feb 26, 2015 12:52 pm
The SS1 uses the same bearing for the back and front of the car so I think it is at fair assumption that the torque is the same. 203/244 stated in the manual for the back axle, is ok for the front.
Post by scimjim » Thu Feb 26, 2015 8:28 pm
Sorry but that's not correct Bill. They're totally different bearings front & back.
Post by scimjim » Sun Apr 07, 2019 6:13 pm
Just found some torque values in the Scimitar Sabre type approval document
Item Page Component Torque NM Torque LBS/FT
51 4 Driveshaft nut. 165NM 122LBS/FT
56 4 Rear suspension pivot bolt. 85NM 63LBS/FT
56 4 Rear shock absorber attachment bolt. 40NM 30LBS/FT
57 5 Rear anti-roll bar mounting bolts. 8NM 6LBS/FT
58 5 Rear anti-roll bar drop links. 25NM 18LBS/FT
85 6 Lower ball joint. 25NM 18LBS/FT
86 6 Upper and lower front wishbone bolts. 25NM 18LBS/FT
88 6 Steering rack mounting bolts. 20NM 15LBS/FT
90 6 Track rod end lock nuts. 20NM 15LBS/FT
92 6 Steering shaft flexible coupling. 20NM 15LBS/FT
94 6 Front anti-roll bar saddle clamp bolts. 10NM 7LBS/FT
97 6 Front anti-roll bar centre bolt. 50NM 37LBS/F
