XJS electric mirrors wiring
ard126k
Been thanked: 27 times
Post by ard126k » Thu Jul 27, 2017 11:50 am
Morning all
I would like to fit the XJS electric mirrors to my GTC. There are a pair on a popular auction site at the moment but I don't want to splash the cash until I'm sure they can be made to work with the GTC wiring. The mirror I have at the moment is the Lotus Esprit style which uses electromagnets to move the shiny bit. The wiring has an earth wire and 4 others, each one gets a voltage depending on how the dash switch is moved. I imagine that the XJS mirrors use motors, which will need the voltage reversed to move in opposite ways (maybe?) As you can see I'm floundering a bit so some encouragement from anyone who's done this would be very welcome!
Alex.
1971 SE5 1977 SE6 1982 GTC
Has thanked: 153 times
Been thanked: 1038 times
Post by scimjim » Thu Jul 27, 2017 1:29 pm
I think the XJS uses 4 wires - a pair for each motor which simply swap polarity to reverse direction?
Has thanked: 48 times
Been thanked: 248 times
Post by AJL Electronics » Thu Jul 27, 2017 2:46 pm
Yes they do. One from each is commoned in the standard circuit. There is an article on here with the instuctions somewhere, I think it is one of mine, using the common Ford switch.
Been thanked: 380 times
Post by peter freeman » Thu Jul 27, 2017 3:46 pm
Use a PP3 battery to test before wiring to the cars 12volt
Has thanked: 282 times
Been thanked: 225 times
Post by Corky » Thu Jul 27, 2017 4:16 pm
When I restored no.404, I just left the original switches in place on the dashboard, but tucked an XJS double switch unit into the centre console box. I tried using a ford switch, but somehow managed to blow three of them, so just went for the proper Jag switches.
ard126k
Post by ard126k » Fri Jul 28, 2017 9:54 am
So I can take it that the Jag mirrors won't work with the GTC's joystick but need a Jag or Ford switch? (Sorry for density)
Alex.
Post by AJL Electronics » Fri Jul 28, 2017 11:13 am
I don't actually know. Have a look at the 6b wiring diagram and see how it is wired. You could also test Voltages at the mirror end. My inclination is that it will work in the same way as the Ford switch. I didn't bother testing with an original switch because the Ford one is much nicer.
Geraint SabreGTCse5
Been thanked: 44 times
Post by Geraint SabreGTCse5 » Fri Jul 28, 2017 12:30 pm
Alex.
yes i had a GTC that had XJSs mirrors using the ford switch BUT there was a little plastic box attached to the wiring just behind the switch curiosity got the better of me while i restored it. I opened it up and there was a small circuit board with all sorts of electrickery on it.... quietly closed it as it was working fine. Car is now on the continent so i can't get pics. The ford switch fitted is quite expensive to replace so i would take advice from an automotive spark before using it.
Geraint
Sabre ti, se5, GTC, 6b.......
Post by AJL Electronics » Fri Jul 28, 2017 12:58 pm
The Ford switch was fitted to many vehicles, Ford, Middlebridge and even Citroen! They are freely available for a fiver upwards, but if buying, look for one with a short length of cable loom attached, otherwise it will be difficult to connect.
ard126k
Post by ard126k » Sat Jul 29, 2017 12:47 pm
Is this the Ford switch? http://www.ebay.co.uk/itm/291851438845 ? Hope it is, I've always liked it in my sister's Fiesta!
Post by AJL Electronics » Sat Jul 29, 2017 1:22 pm
Yes it is. There is also a version with a squarer bezel.
Post by AJL Electronics » Sat Jul 29, 2017 1:23 pm
This would be good... http://www.ebay.co.uk/itm/Ford-Fiesta-M ... Swc2FZdTKS
s-l1600 (4).jpg (137.45 KiB) Viewed 2728 times
Post by AJL Electronics » Sat Jul 29, 2017 1:40 pm
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Sat Jul 29, 2017 2:03 pm
no, that doesn't look like the original ones fitted to my 6b/GTC
Geraint
ard126k
Post by ard126k » Sat Jul 29, 2017 6:34 pm
Could you pop up a photo please Geraint?
