5/5a Metal Bracket / u channel in nose section
Gary
Re: Metal Bracket / u channel in nose section
Post by Gary » Fri Feb 10, 2017 1:33 pm
philhoward wrote:You might find that it might not seem to fit when you get it; the body might need a little bit of a tease to get it back in line if it's been sagging. A bit of 4x2 (I used an offcut of fence post) under the ledge behind the number plate and a gentle "take the weight plus a bit" with a trolley jack should get it back in line while you fit it.
Thanks for that Phil - Yes I reckon the body has dropped somewhat, that's a great suggestion.
gtcse8 wrote:Should be with you soon Gary
According to website Nightline have it in transit.
On assembly you will notice that there are holes pre drilled for the horn wires to feed through, don`t trap them between the steelwork when bolting it down.
Cheers Mark, no panic at all. Thanks for the heads up on the horn wires.
1972 Scimitar Se5a
Registration No: ZV 24816 (Formerly LYV 174K)
Has thanked: 34 times
Been thanked: 157 times
Post by gtcse8 » Fri Feb 10, 2017 1:40 pm
Gary yours looks very bad.
Are the side plates still serviceable as the new nose plate bolts down onto those parts, I have put slots in to allow the new steel to be pushed into the front of the car to help get the 1/2" bolts through the bumper irons and fibreglass
EX SST 1800Ti
Gary
Post by Gary » Fri Feb 10, 2017 2:13 pm
The side plates on mine are actually okay, small bit of rust transfer to one but I have cleaned that up now.
Wish I could say the same about the bumper over riders, they crumbled to pieces when I unscrewed the bolts.
1972 Scimitar Se5a
Post by gtcse8 » Fri Feb 10, 2017 2:29 pm
I may have some reasonable chromed over riders in my stock of spares.
The over rider mounting bracket goes through the front of the car and bolts to the underside of the new mounting with the 5/16" unf bolts provided in the fitting kit.
EX SST 1800Ti
Gary
Post by Gary » Fri Feb 10, 2017 2:48 pm
Thanks Mark, I just bought a 2nd hand set off Graham Walkers earlier today.
1972 Scimitar Se5a
Gary
Post by Gary » Wed Feb 15, 2017 9:13 am
My bracket arrived in the post yesterday - very impressed with the quality of part and the workmanship gone into it, jeez even the packaging was top class!
Well that's my Saturday morning planned now - happy days :D
Can't thank you enough for this Mark.
Regards,
Gary
1972 Scimitar Se5a
Post by gtcse8 » Wed Feb 15, 2017 1:14 pm
Have fun
EX SST 1800Ti
Stupopt1
Post by Stupopt1 » Wed Feb 22, 2017 5:12 pm
Hi
I've just got hold of a Se5 and the front cross member is very rusted, have you got any of these left ?
Stuart
Scimitar Se5
Spitfire Mk4
Post by gtcse8 » Wed Feb 22, 2017 6:10 pm
Hi Stuart
Your in luck, got just One left with the Internal mounted nuts.
PM me and I`ll let you know prices etc.
EX SST 1800Ti
Stupopt1
Post by Stupopt1 » Mon Feb 27, 2017 10:11 am
Hi Mark
Received today , looks excellent
I know no one will see it , but at least I'll know it's all nice and shiny under the front.
looking forward to fit it on the weekend
Thanks again
Stuart
Scimitar Se5
Spitfire Mk4
Post by gtcse8 » Mon Feb 27, 2017 10:50 am
""11:11 am
Hi Mark
Received today , looks excellent ""
Well that`s good service from TNT, just seen the time.
EX SST 1800Ti
Rev Light
Been thanked: 30 times
Post by Rev Light » Sat Jun 03, 2017 7:38 pm
Might be a bit late, but are there any others available, or are there any plans to make any more?
Mine is still there, but full of holes.
Steve.
SE5a 'Fancier'
Post by gtcse8 » Sat Jun 03, 2017 10:28 pm
Steve I have a "Blank" that I could make into a finished item if you so wished.
Would need to know your preference on over rider mountings, either bolts, studs or just holes for bolt and nut fixing.
If another few people wanted these I could do another production run.
EX SST 1800Ti
Rev Light
Post by Rev Light » Sun Jun 04, 2017 8:54 am
Mark,
Captive nut please.
SE5a 'Fancier'
Harry Granger
Post by Harry Granger » Wed Aug 23, 2017 9:43 pm
Please tell me there are some more to be made in the pipeline? :)
Harry Granger // 1971 SE5a
