SE5a sill re-inforcement diagram
DarrylWebb
Has thanked: 70 times
Post by DarrylWebb » Sat Oct 03, 2015 5:04 pm
Potentially looking like this in the flesh,
here are some measurements for making a replacement.
Unless you're OCD about originality I wouldn't go anywhere near metal replacements. :w
I'd make a former from wood, cover with packing tape, then lay up 3 layers of 450g chopped strand matt.
Fit to the car on a bed of P40, or stick it in with Sikaflex/TigerSeal/ etc., then a layer of CSM over the lot for good measure.
Been thanked: 561 times
Re: SE5a sill re-inforcement diagram
Post by Roger Pennington » Sat Oct 03, 2015 7:49 pm
If you *are* thinking of a metal replacement, then presumably stainless is the only option worth going for?
ps. for posterity, I've made it sticky (rather appropriate for a post about fibreglass) :wink:
DarrylWebb
Post by DarrylWebb » Sat Oct 03, 2015 8:51 pm
Knew I could count on you, Roger. :)
Pepe
Post by Pepe » Thu Nov 19, 2015 9:35 pm
If slightly modified, it can be fitted from underneath when Body is off the frame - in a twisting motion...
Leaves paint and Sills unmolested, but involves a nasty, dusty grinding job with a power file from underneath the body, reglueing with Sikaflex 252 (which according Victor doesn't stick to stainless very well) and bonding the edges for stability reasons.
1975 SE5a restoration link
Image Image
simmit
Has thanked: 130 times
Been thanked: 8 times
Post by simmit » Sat Nov 21, 2015 9:55 pm
Hi, I'm a newbie and interested to know more about rusted out cills and outriggers generally as they seem the major problem areas.
It's being advocated here not to use steel as replacement for cills. How does this advice stack up for MOT inspections? Is it not a safety issue? Is there any alternative than steel for outriggers?
Bear with me, I'm new round here and haven't yet got a scimitar but just started looking and so this sort of thing is interesting.
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Sat Nov 21, 2015 11:05 pm
This part isn't structural and isn't part of the chassis - it's embedded in the bodyshell at manufacture (the steps in the door apertures).
Outriggers and side rails are replaceable in situ. Also look at rear diagonals and rollbar lower mounts.
simmit
Post by simmit » Sun Nov 22, 2015 9:00 pm
"Outriggers and side rails are replaceable in situ. Also look at rear diagonals and rollbar lower mounts."
Are these things easily viewed from underneath?
scimmy_man
Been thanked: 37 times
Post by scimmy_man » Sun Nov 22, 2015 9:13 pm
very easily
DarrylWebb
Post by DarrylWebb » Fri Dec 04, 2015 6:01 pm
Absolutely. The front out-rigger can be seen without even getting down on your knees. Just look in the front wheel-arch.
The side-rail runs directly back from the outer end of the outrigger.
nutgone
Has thanked: 59 times
Post by nutgone » Mon Dec 07, 2015 7:43 pm
OK, another newbie here. I've done lots of welding on all metal cars, underneath, patching holes in floors, repairing chassis rails & floor separation. But I've never done anything on a GRP body before. But yesterday (amongst much drama & calamity) I picked up my first Scimitar, a 1974 SE5a, so I want to ask, how do you replace the outriggers in situ?
If you could point me in the direction of an info source, like another thread or something (I may have a little search in the meantime although they're not top of my list right now as the car has a recent MOT) that would be great, or just a brief explanation of what's involved. More for curiosity than anything else right now, although my front ones are a little crusty.
Post by Roger Pennington » Mon Dec 07, 2015 8:06 pm
Welcome to the forum, and good luck with the car :D
Coincidentally, the topic of chassis repairs came up in Matt's project thread, here. Although this was for an Se6, the basic principles don't change much.
nutgone
Post by nutgone » Tue Dec 08, 2015 5:09 pm
Roger Pennington wrote:Welcome to the forum, and good luck with the car :D
Great stuff, answered all my questions & more. Thanks.
limegreen5A
Post by limegreen5A » Fri May 20, 2016 9:34 am
Hi,
Does anyone have any sill-reinforcement pieces made up that they dont need - my drivers side is well past it and keen to either replace the steel or do a glass fibre repair as people have suggested.
Just wanted to check before I see if I can find someone who may be able to make up pieces for me
thanks
pete
Pete Fox
Monza Blue (was Lime Green!) '73 Se5a slowly being restored (slowly being the operative word!)
Botcots
Post by Botcots » Thu Jun 20, 2019 12:22 pm
Does anyone have the dimensions as stated in the first post on here? I'm guessing it's due to the age of the post (but could be my computer!) but it appears the image with the dimensions is absent...?
The sill reinforcement is a job I've been putting off doing - but it's holding up the restoration, so I really need to crack on soon!
Thanks in advance,
Oli
Post by scimjim » Thu Jun 20, 2019 12:49 pm
Is the sill reinforcement in this thread?
