small sports chassis weight
Been thanked: 176 times
Post by BigBobPilot » Wed Sep 11, 2019 7:22 am
It's all on topic!
Jim has a screen surround metal work hanging up in his workshop. I hefted it in my hand, but I don't know the weight of it.
If you get a chance Jim, would you be able to weigh it?
SS1 CA18DET race car
Dcrosby13
Been thanked: 137 times
Post by Dcrosby13 » Wed Sep 11, 2019 7:25 am
I still have the surround and screen kicking about in one piece I will weigh it later
I break stuff...... :w
Has thanked: 186 times
Been thanked: 1269 times
Post by scimjim » Wed Sep 11, 2019 8:18 am
I reckon you’re not far off on screen weight Ben. The GRP surround is pretty thick but I think the metalwork is only a few Kg.
Been thanked: 164 times
Post by reliant-reviver » Wed Sep 11, 2019 8:27 am
The thing I had only recently discovered is that the metal work within the header rail is actually one piece of box section slipped inside another, not sure if that is the whole way across as I was in a hurry to just get it all cut up.
I think part of the reason for the whole surround being quite heavy is the amount of mastic / filler that ties the inner and outer skin together with the metalwork embedded between.
You could I suppose remove all this metalwork and tie the screen surround into the cage at a few points.
Has thanked: 378 times
Been thanked: 265 times
Post by Corky » Fri Sep 13, 2019 6:14 pm
I weighed my screen today, and it came out at 8.2kg
Post by BigBobPilot » Sat Sep 14, 2019 1:58 pm
Thanks Steve. I realised I'd been slightly number dyslexic, my post below says 9.8 kg, but I had meant 8.9kg. Either way, the screen is lighter than I thought. I'll show my hand now too, the 4mm thick polycarbonate screen I cut out a while ago is 3.4kg, so it still represents a 4.8kg weight save if/when swapped.
Post by scimjim » Mon Sep 16, 2019 12:11 pm
The header rail is 3/4” box going all the way down to the “feet” that are bolted to the chassis.
The bit slipped inside at the top centre appears to be a 100mm section to set the width when the tub is laid up.
Down the side of the screen it’s further strengthened by a piece of 1/2” square tube welded to the front face, all the way down to the bottom.
As well as thick GRP layup there is a huge amou t of heavy filler in the surround.
Post by reliant-reviver » Mon Sep 16, 2019 12:54 pm
Interesting stuff! Glad to let you have done the digging out as I didn't fancy it.
Trust me to find the thickest part to cut through with the mid joint :roll:
Post by scimjim » Mon Sep 16, 2019 1:10 pm
I completely removed the metalwork from my first mock-up tub for G97 and filled the void with expanding foam - figuring that the 6 point roll cage would do the same job. In the end I didn’t do it on the current tub as I wasn’t sure if the screen would flex too much.
Can’t find my scales at the moment but I’d estimate 3 or 4 Kg?
Post by BigBobPilot » Tue Sep 17, 2019 3:58 pm
Cool, thanks Jim.
Dcrosby13
Post by Dcrosby13 » Fri Dec 27, 2019 11:23 am
Just been reading the PDF and it states 5KG for a trailing arm, they feel alot heavier than that
Post by scimjim » Fri Dec 27, 2019 4:48 pm
That’s what I made it
scimjim wrote:
Sun Dec 29, 2013 6:22 pm
Didn't see this before I went to the workshop or I could have weighed an LSD too. Digital scales didn't want to play so the old skool scales are only accurate to 500g:
Prop - 3.5
Trailing arm (poly bushed, otherwise totally bare) - 5.0
Front upper wishbone (balljoint and rubber bushes fitted) - 2.0
Front lower wishbone (balljoint and rubber bushes fitted) - 2.5
Standard caliper (with pads) - 3.0
Metro turbo caliper (with pads) - 3.5
Volvo caliper (with pads) - 4.0
Standard disc - 2.0
GW vented disc - 3.0
Reliant upright, hub and disc - 6.5
Chevette upright, hub and Carlton disc - 8.0
Rear brake drum - 3.5
Rear backplate c/w shoes etc - 4.5
Standard fuel tank c/w sender, filler neck and vent pipe - 8.0
Steering rack - 5.5
Front crossmember - 2.5
Front springs (shortened - pair) - 5.0
Rear springs (shortened - pair) - 3.0
Hardtop (with sunroof) - 20.0
Gearbox (with gearstick, no Bellhousing) - 30.0
Steel CVH Bellhousing - 10.0 (as an example, the Caterham alloy Bellhousing for the K series to type 9 is 5.0 and the Sierra 2.8 alloy Bellhousing is 3.0!)
7.5" diff - 27.0
Front ARB - 4.0
Rear ARB - 2.0
Has thanked: 592 times
Been thanked: 519 times
Post by CNHSS1 » Tue Dec 31, 2019 8:49 pm
Hub inc bearing
Hub less bearing approx 1750g
Post by CNHSS1 » Tue Dec 31, 2019 8:52 pm
AP alloy 4 pot vented caliper inc mounting block to suit SS1 upright
Been thanked: 146 times
Post by Oaksey » Tue Dec 31, 2019 11:05 pm
I hope you're not in charge of the weight loss programme on your Ti :lol:
(Arm with bushes)
1973 Beige Se5a Overdrive
1969 Se5
1972 Se5a
2005 Honda S2000
2016 BMW 330d
