small sports steering rack
wiggedy7
Post by wiggedy7 » Tue Jun 19, 2012 4:54 pm
Hi all
Whats the steering rack on a 1600 ss1 off of?
Been thanked: 385 times
Re: ss1 steering rack
Post by peter freeman » Tue Jun 19, 2012 4:57 pm
Chevette
Has thanked: 50 times
Been thanked: 258 times
Post by AJL Electronics » Tue Jun 19, 2012 6:19 pm
ISH! The spindle is a slightly different length on the Chevette offering. It makes the steering wheel rub on the surround. I was looking round for a different u/j to take up the difference, until I put a Reliant one back on.
I have a Chevette and a Reliant one available for sale if anyone needs one.
Been thanked: 560 times
Post by Roger Pennington » Tue Jun 19, 2012 7:18 pm
Isn't the bog-standard chevette one slightly lower-geared than the original standard SS1 one? I choose my words carefully because what your car has now may not be what it had when it left the factory :)
Has thanked: 77 times
Been thanked: 706 times
Post by philhoward » Tue Jun 19, 2012 7:39 pm
There are slight differences in the (at least) 2 variants - and pinion length is the difference. This was also a change on the Small Sports at some point - Sabres have one type and early SS has another but I have no idea when the change is (although I think a change in the casing is the key?).
Yes, Roger - Chevette is 2.9 turns vs SS 2.7 turns, IIRC.
Has thanked: 101 times
Been thanked: 153 times
Post by reliant-reviver » Tue Jun 19, 2012 8:12 pm
Chevette is more like 3.5 turns in my experience.
Can be fitted but you will need to max the ajustment of all slip joints in the column etc.
Oh and perhaps take a dotary sanding disc to teh back of the wheel quickly! YOu may scorn, but seriously, not visible, and does the job of giving you enough clearance for a squeak free column shroud
Has thanked: 428 times
Been thanked: 368 times
Post by CNHSS1 » Tue Jun 19, 2012 8:15 pm
3.5t chevette vs 2.9t ss1.
I haven't checked back to back, but im pretty certain chevette has tad more lock (few mm)
td99
Has thanked: 17 times
Been thanked: 33 times
Post by td99 » Tue Jun 19, 2012 8:20 pm
Chevette definately has more lock. Also steel bushes at either end instead of plain aluminium housing. Better quality build in my view.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
wiggedy7
Post by wiggedy7 » Tue Jun 19, 2012 8:51 pm
What condition is the ss1 rack in?
Poppy
Post by Poppy » Wed Jun 20, 2012 12:08 pm
Dismantle the flexible joint used on the SS1/Sabre, insert another rubber disc and re assemble. This makes up the extra length required for the Chevette rack.
Tony
steve bryant
Post by steve bryant » Wed Jun 20, 2012 12:19 pm
i was looking into using a golf mk1 rack, they look very close........hmm, the pinion is different length [sorted] and dia. [sorted] the pinion is a slightly different angle,[ not sorted but easy, i think] the mount rubbers are very slightly different, [off the shelf, cobra 8) ] but i will get it to fit, once it warms up.
Post by reliant-reviver » Tue Jun 03, 2014 7:52 pm
Dragging this up from the depths as I've done some measuring and comparisons today which will follow shortly.
Could someone else out there with a Chevette rack carefully count the turns lock to lock with it on the bench.
The one I have comes up at 4.2 turns and I have no reason to think it is anything other than common Chevette spec, but would like it confirmed!
Has thanked: 154 times
Been thanked: 1051 times
Post by scimjim » Tue Jun 03, 2014 8:09 pm
KAB definitely has a shovit rack - coz I removed it in the scrappies and fitted it about 15 years ago! I have half a dozen or so racks fitted/unfitted I can check - all ss1 AFAIK (139-982) but there may be a Sabre one in there if BFD came with one?
Post by philhoward » Tue Jun 03, 2014 8:36 pm
BFD didn't - the one "with it" is SS1...
Post by CNHSS1 » Tue Jun 03, 2014 9:02 pm
Stew B had the rack rebuilt on L320 BFD, but thought it was original. Will check at the weekend RR
