SE6A clutch pushrod - how does it go together???
Diyhell
Post by Diyhell » Tue Oct 13, 2020 9:52 am
Just putting my clutch back together, on the long crawl to engine going back in.
But I can't work out where everything goes - I seem to have more parts than are in the parts diagram?
Specifically the red ringed parts that don't appear in the parts diagram?
Cluth parts.png (136.47 KiB) Viewed 107 times
And I have a domed aluminium 'washer' on the end of my pushrod.
It's been some time since I took this apart and I'm now wishing I'd taken a picture!
SE6a needing lots of work...
rjudcsx
Post by rjudcsx » Tue Oct 13, 2020 10:31 am
Might be wrong but have you got some gear linkage parts mixed up with your slave cylinder bits . The clip on the left looks very much like one used to connect the gear rods to the selector leavers ,via a bush , which has two metal washers either side , like the two in your picture ? Regards Richard .
Post by peter freeman » Tue Oct 13, 2020 10:39 am
You have mixed up parts of the gear change with the clutch parts
Diyhell
Post by Diyhell » Tue Oct 13, 2020 11:30 am
rjudcsx, peter freeman, thanks! I totally see what you mean now.
The annoying thing about it is that I failed to bag everything as I'd intended - which 18 months later results in confusion...
