Drivers footwell carpet soaking se6a
martin F
Post by martin F » Fri Oct 02, 2020 6:51 pm
Gents, is there a known place where water gets in while the car is parked in a downpour?
Windscreen corners by any chance?
Everywhere else is bone dry.
thanks
Martin
1980 Scimitar GTE SE6A daily driver
1971 Triumph GT6 V8 weekend warrior
1973 Triumph Stag in resto
Post by philhoward » Fri Oct 02, 2020 7:01 pm
Windscreen, wiper spindles, door seals to name but 3.
Drury
Post by Drury » Fri Oct 02, 2020 7:13 pm
Prime suspect is the windscreen seal in the bottom corners. Try Captain Tolleys sealer.
martin F
Post by martin F » Fri Oct 02, 2020 7:36 pm
thanks guys i'll investigate those areas..
Actually just changed the drivers wiper wheelbox for a further sweep 32 teeth one this afternoon, so the new inner/outer plinths should rule out that point from today.
Martin
rjudcsx
Post by rjudcsx » Fri Oct 02, 2020 7:36 pm
Had the same problem with my 5a , managed to get some Capt T and I was a bit sceptical but followed the instructions and put it around front screen and rear side windows , worked a treat. I had put a light dust of talc on the inside trim and this helped me id the point of ingress , but it could run along a frame and then drip , also put a bit around my aerial . Do not ignore the door seals , if not seated right they could also be a problem . Richard .
Post by AJL Electronics » Fri Oct 02, 2020 7:48 pm
Radio aerial. The hole opens into the offside kick panel and any water ingress appears in the driver's footwell.
martin F
Post by martin F » Fri Oct 02, 2020 8:02 pm
thanks again!
I only noticed because back of my head got wet while i was upside down fitting the wiper wheelbox!
