SE6a steering play in upper column bush
martin F
Post by martin F » Mon Sep 28, 2020 3:11 pm
Afternoon, I've only just paid membership so can't access the wiki yet, so figured i'd ask.
Parts diagrams show the se6a upper steering column bush as part No. SKU: 211706, but another website gives an equivalent number as 26575,
This 2nd number is the same code as a Reliant Robin steering bush. Is that correct are they actually the same?
Martin
1980 Scimitar GTE SE6A daily driver
1971 Triumph GT6 V8 weekend warrior
1973 Triumph Stag in resto
Post by scimjim » Mon Sep 28, 2020 3:29 pm
Bush 211706 is used with column outer 211698, bush 26575vis used with column outer 213403. I have no idea what the difference in columns are and the parts manual doesn’t show any chassis number applicability.
martin F
Post by martin F » Mon Sep 28, 2020 3:35 pm
ok thanks Jim, i guess i'll try to identify my column or take a chance.
Thanks again.
Martin
Terry Rickard
Post by Terry Rickard » Mon Sep 28, 2020 4:23 pm
Just order from QRG or Graham Walker and state the car model (SE6a) when ordering.
Post by gtcse8 » Mon Sep 28, 2020 4:34 pm
26575 from Reliant partsworld comes with Two plastic press in bushes for top and bottom.
I have always used these, but usually only needed for the top.
They can be pressed in and push the old worn bush down a little so no need to remove it.
Terry Rickard
Post by Terry Rickard » Mon Sep 28, 2020 4:37 pm
Good tip Mark. I always use two at the bottom, first pushed further up, then they seem to last longer.
