Manual or Automatic ?
markpin
Post by markpin » Fri Sep 25, 2020 5:16 pm
Hi
I was wondering if its worth converting from Auto to Manual if you want to sell on a 6A? I have one, possibly two auto's which I intend to sort out over the next year but I also have every thing I need to convert one or both to Manual. I am just curious if there is much difference in value between the two. Obviously conversion away from factory does make a difference I accept but I am wondering if Manuals are much more sought after, thus justifying the conversions?
Post by AJL Electronics » Fri Sep 25, 2020 5:23 pm
No, the work isn't justified value wise or desirability wise. An auto in a 6 series is well suited to it, whereas a 5 might be more suited to a pudding stirrer.
Post by peter freeman » Fri Sep 25, 2020 6:05 pm
I hated the 3 speed ( GTC ) auto we had but love the 4 speed MB. I understand the 4 speed auto box is not that difficult to fit - if you can find one
Drury
Post by Drury » Fri Sep 25, 2020 6:22 pm
The BW 35 auto box is dreadful. Never had a 6b with the Ford C3 but can imagine it's no better.
Post by scimjim » Fri Sep 25, 2020 6:42 pm
It’s not that easy to fit an A4LD to the Essex and although it’s much nicer than the C3 (or BW35), the only real problem with them is the lack of overdrive (ie high revving, lower mpg).
As to the question, Andy has answered - not a lot of difference in price or desirability whether OEM or converted (unless it’s a particularly original car).
Post by AJL Electronics » Fri Sep 25, 2020 7:30 pm
Why be negative about something of which you have no experience?
Post by philhoward » Fri Sep 25, 2020 7:56 pm
My SE5 with a BW35 was great. What’s dreadful about it? The C3 is a bit more refined but as you’d expect for another decade of progress.
Post by peter freeman » Fri Sep 25, 2020 8:31 pm
I went from 6A with a Rover V8 ( I fitted ) to a GTC auto and the difference in revs did my head in - the MB auto is completely different.
Drury
Post by Drury » Fri Sep 25, 2020 8:34 pm
My first auto was a 5a. IMO it has too big an affect on fuel consumption, acceleration and traction in snow and ice. I also disliked not being able to hold a lower gear unless you changed manually. Put me off autos until recently when my daily driver became a BMW 330d touring (modern day Scim) with the eight speed auto which I love.
Post by scimjim » Fri Sep 25, 2020 9:18 pm
surely that’s the same for any gearbox?
Post by AJL Electronics » Fri Sep 25, 2020 9:32 pm
Not only that, kickdown drops and holds it in low gear.
Drury
Post by Drury » Fri Sep 25, 2020 10:41 pm
Relax the throttle and it changes up again.
Post by scimjim » Fri Sep 25, 2020 10:58 pm
just like your BMW does?
Scim8tar
Post by Scim8tar » Sat Sep 26, 2020 11:04 am
What gearbox did you use in your V8 conversion Peter ? would be interesting to hear the conversion story and how it drove compared to the essex.
Paul
Post by peter freeman » Sat Sep 26, 2020 11:53 am
Type 9 as fitted to the Jags - did a write up which Sam out on his V8 church site - he also got a number of exhaust manifold made. http://www.v8church.co.uk/your_cars/35_ ... itar_ID_1/
