Spark Plugs What are you guys using in the Essex V6 ?
adamwilkes
Post by adamwilkes » Sun Oct 18, 2020 9:08 am
My carbon -cored leads have each total 5-10KOhms depending on length. I'd guess that was plenty to justify a non-resistive spark plug, bearing in mind that copper leads have virtually zero resistance.
Adam Wilkes
Post by scimjim » Sun Oct 18, 2020 9:16 am
Sorry, I pressed edit instead of reply and changed my previous post asking what the resistance of the leads are :oops:
Post by scimjim » Sun Oct 18, 2020 9:17 am
Magnecor (apart from their copper lead) list 2-3k ohm per metre.
Post by Old and Slow » Sun Oct 18, 2020 11:50 am
The NGK datasheet says the resistor plugs are 5kohm which would tie in with resistive leads being around 5k.
the 7 version mentioned by Jim is a colder plug than the 6 but with the change to enthanol-based fuel there might be some advantage in running hotter plugs, especially in cars that do low mileage as there is a possibility of the ethanol evaporating out of the fuel whilst left standing. Sooty plugs tends to mean rich fuelling and/or cold plugs, I think.
The NGK CLASSIC CAR plug schedule lists the BP6ES for Scimitars.
Scimmetry
Post by Scimmetry » Sun Oct 18, 2020 12:33 pm
The subject of spark plugs and running hotter plugs has been brought up a few times at work especially with older design engines & modern fuels.
Within the company the current advices for older engines is if there are issues with missfires or fouling of a plug to try a plug that is one heat range up from the normally recommended plug heat range if no other obvious issue.
Going by that I was going to try the scimitar with BPR5ES plugs as its currently fitted with BPR6ES.
Jr
1976 SE6
Post by Old and Slow » Sun Oct 18, 2020 8:01 pm
Provided you have copper strand HT leads (and not carbon string, or Champion Plug Caps which have a built-in resistor) then those should be OK, I think.
Steve_S
Post by Steve_S » Sun Oct 18, 2020 9:09 pm
Iv ended up putting Champion Copper Plus Spark Plug N9YC
