GTC door mirror
philipmasonfrance
GTC door mirror
Post by philipmasonfrance » Wed Sep 02, 2020 5:00 pm
More years ago than I care to remember the spring in the driver's door mirror broke, leaving it flopping around. It's so long ago that I can't remember how I re-attached it, but I think a self-tapping screw on the inside was involved. Aesthetically quite effective - but no spring-back mechanism for x years. I'm thinking a bolt with a nyloc nut and a strong spring might do the job - but does anybody have any (neater/easier) suggestions please?
GTC door mirror
Post by gtcse8 » Thu Sep 03, 2020 8:51 am
Hi Phil
Cheque arrived, thanks.
You could only use a bolt through the base and head to make the unit flip if you removed the glass operating cables.
I have lots of heads that the mild steel pivot has rotted away and the large spring clip has disintegrated too.
IF you still have SOME of the mild steel pivot boss left you could IN theory thread it to accept a nut that would retain the spring enough for the head to flip.
Not tried it myself, but have thought about it a bit now I have found all the mirrors I have collected over the years.
philipmasonfrance
GTC door mirror
Post by philipmasonfrance » Thu Sep 03, 2020 9:17 am
Hi Phil
Thanks, Mark. I'm tackling the fouling on full lock issue at the moment (in between trying to make the passenger seat - ex-driver's seat - more rigid/less floppy) so I'll take a look at the mirror after that. Thanks for the suggestion. Never a dull moment!
ard126k
GTC door mirror
Post by ard126k » Thu Sep 03, 2020 5:50 pm
I'm sure I've seen tube with thread on the outside - would that help??
Also I have a spare Jaguar mirror case with a very strong spring if nou need one.
Alex.
1971 SE5 1977 SE6a 1982 GTC
philipmasonfrance
GTC door mirror
Post by philipmasonfrance » Thu Sep 03, 2020 6:41 pm
Alex.
Thanks, Alex, but mine are the (original???) Granada (???) type mirrors. Not sure if they're clear on the photo.
LHD dash.jpg (204.44 KiB) Viewed 229 times
I'll see how I get on, but thanks for the offer! Phil
GTC door mirror
Post by gtcse8 » Thu Sep 03, 2020 6:58 pm
Did not realise yours was a Left hooker. :doh:
So YOUR drivers door is a Passenger side GTC :roll:
I have a few of those :wink:
I once bought a NEW Blue centre console from GW and it was only after I sold it we realised it was for LHD :roll:
Northyorkshireman may still have it if yours is past it??.
philipmasonfrance
GTC door mirror
Post by philipmasonfrance » Fri Sep 04, 2020 8:14 am
Go on then. Christmas is coming. Please PM with the price for the passenger (UK) door mirror. It's with manual adjustment please. As an aside, when Geert van Hout converted her to LHD, he did the whole job 100% and installed a new LHD centre console too - and moved the handbrake from right to left. Only problem is, it's impossible to select reverse gear with the handbrake applied! So reverse hill starts are challenging, to say the least. Even BMC/BL didn't bother to swap the handbrake on the MGB for LHD!
