Replacement alternator
5eon
Post by 5eon » Sun Aug 23, 2020 2:10 pm
I'm upgrading my alternator, I was going for a 65Amp but I've seen a 75Amp at the same price, would this be overkill or present any problems?
Post by gtcse8 » Sun Aug 23, 2020 2:14 pm
Not at all.
I fit alternators that are also from Canal Barges with up to 90A.
They have an extra battery take off fitted and this supplies 14v at tickover, so I just wire it direct to the battery and it keeps the power up even at idle speeds.
Last set I bought were less than £60 each.
Post by willholderogri » Sun Aug 23, 2020 2:25 pm
I had a 100 amp on mine
Post by philhoward » Sun Aug 23, 2020 2:42 pm
None of those mentioned are safe on standard wiring (as eluded to by Mark) - nothing a good sized cable direct to the battery can’t fix.
5eon
Post by 5eon » Sun Aug 23, 2020 3:44 pm
If I were to replace the brown cables with one new one what size cable would I need Phil? I was going to double up on the brown cables, I have a spare loom, but one new cable might be better.
Post by philhoward » Sun Aug 23, 2020 4:27 pm
Double of the existing size is fine.
Terry Rickard
Post by Terry Rickard » Sun Aug 23, 2020 4:36 pm
Fitting of type A127 alternator has been discussed before on here.
See http://www.scimitarweb.co.uk/sgwrs/view ... or#p497282 about replacement alternator and an extra lead (thick wire) from the threaded post to the battery.
Photo of it here: http://www.scimitarweb.co.uk/sgwrs/view ... or#p499499
Post by peter freeman » Sun Aug 23, 2020 5:32 pm
Fitting a alternator that can give you say 75 amps does not mean it will always give 75amps it will only give what is demanded by the load the car presents. The original alternator was 35 amps which for most of the time was ok but in the winter with the heater, lights, HRW, and perhaps when in traffic the rad fan also on it was a real struggle for the 35 amp alternator so current was also drawn from the battery. The first higher power alternator to be available was a 55amp unit and in fact this is what is fitted to my Coupe and it copes with all situations nicely thank you. Then more powerful alternators came along as later cars have more electrical demand - brighter lights for example but if you have fitted some LEDs this is to an extent negated. My MB has as standard a 90amp alternator fitted but demand I think will be no where near that even in mid winter. I'm with Phil fitting a double size wire or the same size in parallel with the current wire between the alternator and battery terminal will be ok.
Post by gtcse8 » Sun Aug 23, 2020 5:43 pm
Depending upon the connectors fitted to the new alternator there should be No need to replace any wires, as Peter pints out the alternator will only supply what is needed.
But you will deffo benefit from a larger wire direct to the battery IF the "B+" terminal is fitted.
