Fan Belt
5eon
Fan Belt
Post by 5eon » Sun Aug 23, 2020 9:49 am
The fan belt on my 6A needs replacing what are the width depth and length for this model (none power steering) I have some belts which I think will fit just need to double check.
Fan Belt
Post by scimjim » Sun Aug 23, 2020 10:03 am
Welcome to the forum :D
1325 x 10 for all 4 pulley Essex.
5eon
Fan Belt
Post by 5eon » Sun Aug 23, 2020 10:35 am
Is that inside or outside diameter Jim, the one I have on is 1346mm O/D, should they be notched (toothed) on the internal face?
Fan Belt
Post by scimjim » Sun Aug 23, 2020 11:32 am
I’ve seen flat and toothed type used - as long as it sits in the vee of the pulleys correctly I don’t think it matters really. I don’t know if manufacturers measure inner or outer (probably inner?) but there’s more than enough adjustment on the alternator to use either.
5eon
Fan Belt
Post by 5eon » Sun Aug 23, 2020 11:37 am
I read that the teeth are to keep the belt running cooler although with a Scim' engine I'm not sure this would work, thanks for your help.
Fan Belt
Post by scimjim » Sun Aug 23, 2020 1:18 pm
Just checked mine and it’s got teeth (3 pulley though)
