Complete confusion, wiring,firing
Oddjobber23
Post by Oddjobber23 » Mon Aug 17, 2020 9:48 am
Hi, I also have been to different car meetings as I have been a bit of an impulse buyer where cars are concerned, and I joined all the clubs for those particular cars. I must say though, this is the friendliest and most helpful club I have had the pleasure to join, it is almost worth buying this overpriced shed just to join. Anyway, I notice that the coil in the wiring diagram is a 9v, the one I bought is a Sparkrite coil/ballast. I bought this from Ebay and when I checked the compatible motors it said it was the right one for my car, and I even gave him my reg' to be certain and he confirmed it was correct for my S plate SE6a, have I knackered my motor before I even get started.
Regards, Alan
Post by scimjim » Mon Aug 17, 2020 9:51 am
Old and Slow wrote:
Mon Aug 17, 2020 9:24 am
A picture's worth a thousand words. - thanks Peter.
Shows my confusion over the White/Yellow wire so ignore what I said!
no, you were correct. During cranking the coil gets full battery voltage. That comes from the starter motor solenoid, bypassing the ballast.
scimrick
Post by scimrick » Mon Aug 17, 2020 12:22 pm
Hi Alan
I've had IT issues last few days so only just seen the thread. As t'other Richard (RJUDCSX) says, I am the Norfolk area Noggin Secretary and contactable via the links in Ard's post above.
Hopefully we can arrange to meet up, I'm in centre of Norwich but can often seen up on North Norfolk coast!
Regrettably we have had to cancel Noggin meeting due tomorrow Tuesday 18th August.
cheers
Richard
Post by gtcse8 » Mon Aug 17, 2020 1:28 pm
Doubt it Alan
Just follow Peters excellent wiring diag and you can`t go wrong, assuming most of the wiring is still in the car??.
Oddjobber23
Post by Oddjobber23 » Mon Aug 17, 2020 9:59 pm
Hi, well the white wire supposedly the ignition wire has been extended with a black wire, and the wire to the distributor is now white, so basically it is a case of hope for the best.
But I must once again thank you all, one for the help and two for being so welcoming to a complete novice.
I had to buy this car anyway because in 1976 at the tender age of 11 I saw a Scimitar and I promised myself that one day I would own one and drive it proudly. Unfortunately this was the only one I could afford and the previous owner has really gone to town pulling everything out and what he has returned to the shell is all over the place.
Regards, Alan
Post by scimjim » Mon Aug 17, 2020 10:08 pm
Worth taking the time to repair and/or replace any dodgy wiring with the right colours - it’s a weak point on just about any 45 year old car, not just Scimitars.
Post by Old and Slow » Mon Aug 17, 2020 11:08 pm
I'd suggest making a list, so that you can work through it a bit at a time.
Getting the ignition working is a good place to begin.
Good luck, remember - there are no silly questions, only silly answers, but we try to avoid them, usually!! :D
Oddjobber23
Post by Oddjobber23 » Thu Sep 03, 2020 7:21 am
Hello, I would like to thank all of you for your assistance I really am very grateful, and it has helped me work out whether I am going to bother with it or not.
Regards, Alan
