Needle valve size
Scim78
Needle valve size
Post by Scim78 » Tue Aug 11, 2020 8:14 am
Hi,
I need a new needle valve on my 38dgas ('78 se6a) What was the standard size?
Ray
Needle valve size
Post by scimjim » Tue Aug 11, 2020 8:58 am
There’s only one size for the float chamber needle valve AFAIK?
Needle valve size
Post by scimjim » Tue Aug 11, 2020 9:01 am
Usually comes as a complete unit
Scim78
Needle valve size
Post by Scim78 » Tue Aug 11, 2020 11:30 am
Found these on Green spark plug website:-
Weber (Replacement) DGAS X-Drilled Needle Valve - 250
Weber (Replacement) DGAS X-Drilled Needle Valve - 200
Weber (Replacement) DGAS X-Drilled Needle Valve - 175
the numbers relate to the size I assume
Ray
Scim78
Needle valve size
Post by Scim78 » Tue Aug 11, 2020 11:41 am
Needle valve size
Post by gtcse8 » Tue Aug 11, 2020 11:45 am
Ray I have a few NEW float chamber valves?.
IIRC the Weber drilling numbers relate to Metric drill sizes, so 175 is actually 1.75mm.
I have just checked a NEW Weber 250 valve and the 250 relates to the size of the INLET hole in mm.
The X-drilling is just to get the fuel past the moving needle valve quicker.
The one in Jim`s picture is NOT X-Drilled.
The one in your post IS X-Drilled, but NOT a Genuine Weber part.
The 38DGAS needle valve for Capri 3000 is listed as 79516.250 and has a 2.50mm inlet. :wink:
Scim78
Needle valve size
Post by Scim78 » Tue Aug 11, 2020 12:10 pm
Thanks . I'll order a 250 size :D
Ray
Needle valve size
Post by gtcse8 » Tue Aug 11, 2020 3:51 pm
I have them in stock, £7 posted.
